Re: Stuck brake drums. REALLY stuck [Re: skicker] #1569077
01/26/14 11:29 PM
01/26/14 11:29 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Starting the nuts on the lugs is SOP for hammering the drum flange.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Stuck brake drums. REALLY stuck [Re: DaveRS23] #1569078
01/26/14 11:33 PM
01/26/14 11:33 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
MAPP gas won't do it here. You need a real torch for this one. Cherry it up good and then get the BFH after the axle while pulling on the drum.
Yes mapp gas is not near hot enough.
I use a BFH, a mini sledge hammer.
Re: Stuck brake drums. REALLY stuck [Re: 3hundred] #1569079
01/26/14 11:35 PM
01/26/14 11:35 PM
Cincinnati, Ohio
Cincinnati, Ohio
I've had good luck hitting the drum with the the ball end of a ball peen hammer between the lugs. It deforms the drum and breaks the rust bond. Sometimes takes a while.
Robert
IMO, this is a very god idea also, exactly what a ballpein hammer is made for.
Re: Stuck brake drums. REALLY stuck [Re: DaveRS23] #1569080
01/26/14 11:44 PM
01/26/14 11:44 PM
Ohio
john55 Offline
john55  Offline
Ohio
this will work, BTDT
The Plymouth Win You Over Beat Goes On
Re: Stuck brake drums. REALLY stuck [Re: john55] #1569081
01/27/14 01:19 AM
01/27/14 01:19 AM
Montana
67DodgeCharger Offline
On vacation
On vacation
Montana
Apply a break free fluid to the axle and drums, go to store and purchase one 12 pack of favorite beer for each day you have off from work, go home and sit in your recliner and drink beer, drink all beer, grab a hammer and beat on the drum and axle, REPEAT
Re: Stuck brake drums. REALLY stuck [Re: 67DodgeCharger] #1569082
01/27/14 01:31 AM
01/27/14 01:31 AM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Greg, I got this.(formerly from the land of the rusty cars)
What needs to happen is clean the axle center register if you haven't already,lube with PB or similar,and pull OUT on the drum outer edges, even if only with a couple of pry bars,(no need for the 'force of God', just some tension)
and use a punch and a small sledge to knock the axle center register IN at the same time.These axles have(or used to)a good bit of end play, and if you "unload' it by prying the drum OUT, and knocking the axle IN simultaneously, it will give.Trust me.
regards,your new neighbor, Case
Re: Stuck brake drums. REALLY stuck [Re: Sixgun] #1569083
01/27/14 10:56 AM
01/27/14 10:56 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Also make sure the small clips they install from the factory are taken off.Ive seen people try to get drums off only to find the thin clips holding them on.Rocky
Chrysler Firepower
Re: Stuck brake drums. REALLY stuck [Re: therocks] #1569084
01/27/14 11:22 AM
01/27/14 11:22 AM
Manistee, Michigan.
High Impact Offline
High Impact  Offline
Manistee, Michigan.
Three things needed:
1) You need a real torch. Heat till cherry red.
2) Use the puller your buddy made with the impact.
3) Big Hammer!
Im in Northern Michigan and have used a three jaw puller and my torch on some terrible rusty drums...It takes alittle time but the heat it the part your missing! And dont be afraid to swing that hammer!!
PS> if its a good puller your buddy made, IF the shoes are stuck inside once that drum break's free you'll pull the retainers that hold the shoe's on off the pins and then you will have to dig out the shoes from the drum with a pry bar or whatever..
Re: Stuck brake drums. REALLY stuck [Re: High Impact] #1569085
01/27/14 12:10 PM
01/27/14 12:10 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Never in 27 years had one that wont come off...
Use a rosebud end on a real oxy/acet rig and heat the center until red hot...Use a prybar between the drum and the backing plate and pop it off...If its hung up on the shoes, it will likely break the holddown pins/caps, but you can replace that stuff after you get it apart..
MB
Re: Stuck brake drums. REALLY stuck [Re: HPMike] #1569086
01/27/14 07:15 PM
01/27/14 07:15 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Once the drums are off coat the face of the axle flange with antisieze or some other compound to prevent future rust issues.
- Stu Harmon
Re: Stuck brake drums. REALLY stuck [Re: feets] #1569087
01/27/14 07:24 PM
01/27/14 07:24 PM
Western NY
19SuperBee70 Offline
Western NY
cut off wheel on a grinder, wear safety glasses. cut a notch and break pieces away with a hammer/chisel. repeat until its all off.
I had to do this with rotors on a liberty. I tried everything and nothing worked. Then buy a spray can of never-sieze and spray the face before putting back together.
Re: Stuck brake drums. REALLY stuck [Re: 19SuperBee70] #1569088
01/28/14 12:11 AM
01/28/14 12:11 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Screrw the . Replace the complete rear end..
I am truckless..
Re: Stuck brake drums. REALLY stuck [Re: 340SHORTY] #1569089
01/28/14 10:51 AM
01/28/14 10:51 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Clean the hubs first before the antisieze.I use my die grinder and a rolox disc.When I cut drums at work I also take off about .100 more where the rust ring build up on the drum.Makes it a bit easier when you pull them again.That part of the drum never sees the shoes so it dosent hurt anything.Rocky
Chrysler Firepower
Re: Stuck brake drums. REALLY stuck [Re: therocks] #1569090
01/28/14 01:20 PM
01/28/14 01:20 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
That's a slick idea, Rocky, I think I'll pull mine now and do that before I put any miles on them.
Thanks, Joe
Re: Stuck brake drums. REALLY stuck [Re: jlatessa] #1569091
01/28/14 09:03 PM
01/28/14 09:03 PM
MN
astrobuf Offline
astrobuf  Offline
MN
The shoes are deeply worn into the drum. There is no point in trying to save the drums. I'd go after the drum with a cut-off wheel and cut it off in two pieces.
You might save yourself some work by grinding the heads off the shoe hold down pins on the backing plate. This might give you enough ability to get the drum off the backing plate enough to release the springs etc with a thin screwdriver slipped in. Might not work though as the shoe ends may still be retained.
Plan to replace all the hardware here as everything will be shot.
Astrobuf
Re: Stuck brake drums. REALLY stuck [Re: astrobuf] #1569092
01/29/14 12:42 AM
01/29/14 12:42 AM
NY NY
3
340duster340 Offline
NY NY
DOT3 brake fluid at the flange. let it sit for a bit and then beat the snot out of it.
don't knock it until you try it.
Re: Stuck brake drums. REALLY stuck [Re: 340duster340] #1569093
01/29/14 01:51 AM
01/29/14 01:51 AM
KY USA
mopargem Online tonguue
mopargem  Online Tonguue
KY USA
Had an 89 D150 with stuck drums at the hub flange and applied heat and hammered and crow barred from back side and they finally came off. BUT not long after, both axle seals leaked and had to pull axles and replace the seals. I think the heat ruined them
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Stuck brake drums. REALLY stuck [Re: mopargem] #1569094
01/29/14 02:12 AM
01/29/14 02:12 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
my preferred method after figting/beating the snot out of too many of them.
i take my die grinder and cut the heads of brake shoe hold down pins off from behind the backing plate...
it saves alot of beating/cutting/effort...
Re: Stuck brake drums. REALLY stuck [Re: Pacnorthcuda] #1569095
01/29/14 02:42 AM
01/29/14 02:42 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
My '99 Caravan was like that, and I was replacing all the brake parts anyway, so I just cut the drums off with a plasma cutter. It gave me a reason to play with the plasma cutter
Re: Stuck brake drums. REALLY stuck [Re: 451Mopar] #1569096
01/30/14 10:34 PM
01/30/14 10:34 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I bought an 8.75" that had been sitting in mud for a couple of years; the lugs were seized. I tried heat with an impact, but they still didn't move. A friend had the idea of heating them up again until cherry, dumping a bucket of water on them, and immediately hitting them with the impact again - sure enough, they spun right off.
