Re: Which engine for a 56 pickup
[Re: savoy64]
#1568757
01/26/14 12:03 AM
01/26/14 12:03 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The Aspen and 5th ave use the same front suspension and most likely the same rear axle and trans.
The engines are pretty much the same.
However, Chrysler made changes over the years to the front suspensions to improve them. All else the same got for the 5th, unless it's all wore out. The 5th and the Aspen both likely have the 7 1/4, though an 8 1/4 was possible. Dimensionally, the axles are the same in either car, dependent on type of axle that is. The trans is most likely the same too, but the 5th might have a slightly heavier duty unit.
[Re: Skid_Demon]
#1568758
01/26/14 12:19 AM
01/26/14 12:19 AM
Posts: 415 Indiana
Pentastar440
Indiana
I would go with the '85 5th Avenue. Engine will be a 'roller motor' , la with roller cam. Master cylinder would work fine, good alternator, probably has a tilt steering column, big radiator, etc.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
[Re: Skid_Demon]
#1568762
01/26/14 01:17 PM
01/26/14 01:17 PM
Posts: 2,648 GA
Boosted
GA
I say buy which ever one is the cheapest with the best motor and trans in it. Roller motor vs non roller motor does not matter unless you are going to rebuild it and want the advantage for HP that a roller cam can give. Both being stock... No big deal at all..
If you really want a roller motor I would look towards the mid 90 dodge trucks.. Grab the motor and trans from a 2wd and enjoy some highway cruising in the old truck. FI and od is the way to go if you have the time to do it.
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
[Re: Skid_Demon]
#1568767
01/28/14 02:46 AM
01/28/14 02:46 AM
Posts: 10,670 Freeport IL USA
poorboy
Freeport IL USA
I am looking at the cars for the engine, tranny and perhaps rear end. I used a volare k member for a 1947 dodge, but now searching for a Dakota k member for this truck. Gene, Is that what went in your 54?
My 54 had a Volari (F body), 5th Ave (M body) and Lebaron (J body) clip under it. Though it worked and drove well, the suspension was a pita to install correctly. I also had to do major surgery to the firewall, the steering column linkage was real tight,, and the suspension was mushy under a hard corner. Sure rode nice though. Since then I've installed 2 Dakota clips and a complete Dakota frame.
My big blue truck that got wrecked was a 50 and it was mounted on an 80 Dodge full sized frame, which was also a ton of work to make correctly. Lots of body modifications on that one.
The Dakota frame lends itself so well as a doner for 40s through the 60s trucks there is not even a close 2nd, especially if you actually want the truck to perform any type of work. Gene
[Re: Flipper1938]
#1568770
01/31/14 07:42 AM
01/31/14 07:42 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
i thought the 318 roller came out in 88 and the 360 in 89 ??
the fifth ave will probably have a hydrulic lock up convertor and possibly a low first gear,, and its newer then the aspen,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
