Re: Vacuum Advance for 340 TA six pack
[Re: Aar1064]
#1568137
01/24/14 08:52 PM
01/24/14 08:52 PM
RapidRobert
Find "Joesixpack" on here & PM him
[Re: RapidRobert]
#1568138
01/24/14 11:30 PM
01/24/14 11:30 PM
Posts: 907 Mississauga, Canada
KARLN
Mississauga, Canada
just curious, why are you running the vacuum advance? My T/A seems to run better with the vacuum advance disconnected and blocked.
B5 Challenger T/A
[Re: Aar1064]
#1568141
01/25/14 01:04 PM
01/25/14 01:04 PM
RapidRobert
I'd get a new one from Joesixpack & tune the dist with it. Initial/total(35)/springs/vac adv in order. It does have advantages such as better MPG, cleaner plugs. They ain't terribly expensive & later you can always cap it & see which way works the best for you. there was a recent post where the adv arm was interfering with the P plate so be aware of that but you already have the P system installed so I'm assuming you are good there just that the can wont hold vacuum. Just me I would highly suggest running it in a street app
[Re: KARLN]
#1568142
01/25/14 01:19 PM
01/25/14 01:19 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Because that is the way it is supposed to be on a street driven car,there is a difference between runs better and drivability . Why do you suppose it was put there to begin with ?
[Re: Aar1064]
#1568145
01/26/14 12:05 AM
01/26/14 12:05 AM
Posts: 11,915 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
sorry i have no dual point vacuum advances....340 dual point vacuum advance...tough to locate,not serviced in the aftermarket...makes it a chrysler/mopar only part i did locate a complete dual point with vacuum advance... http://www.rockauto.com
[Re: Joesixpack]
#1568147
01/26/14 12:21 AM
01/26/14 12:21 AM
RapidRobert
this may be crazy but if a regular can will fit on the side of the dizzy but the dual point arm is different a person might cut/pin the arm from the old can on. It take some swiss watch fabbing skill but there is a fair amount of room in that area. But the can would be different on the outside & I believe you want originality showing so maybe that wouldn't be a good idea. Good luck with everything & holler in the future if you want dist setup help.
