90-91 360 tbi swap to carb bugs
#1568110
01/24/14 07:19 PM
01/24/14 07:19 PM
Posts: 166 California
Hotlumpy
California
My cousin took a 90-91 TBI 360, put a comp cam, Edelbrock heads, intake and carb on it with an electric fuel pump, dropped it into his 74 dart that ran fine with the factory 318, and now it will not run with ought backfiring under hard throttle. The cam was ordered for a 91, he used the factory dart distributor, we have checked timing and spark, been all through the wiring, tried different fuel pumps but to no avail. Did we misss something swapping parts, or should this combo run fine?
Re: 90-91 360 tbi swap to carb bugs
[Re: Hotlumpy]
#1568111
01/24/14 07:30 PM
01/24/14 07:30 PM
Posts: 15,487 Florida
scratchnfotraction
a 90 -91 360 should have a roller lifter cam. did he replace it with a roller cam? maybe another comp cams that has wiped out a cam lobe. ![](/ubbthreads/images/graemlins/runaway.gif) what kinda dist from the dart? elect? points? what carb on it.. going lean and poping maybe? ![](/ubbthreads/images/graemlins/drinking.gif)
[Re: Hotlumpy]
#1568113
01/24/14 07:49 PM
01/24/14 07:49 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
now has a brand new Edelbrock 750.
no wonder it wont run...
are you running a orange box ? check the reluctor gap in the dist. whats your fuel pressure ?
I am truckless..
[Re: 340SHORTY]
#1568115
01/24/14 08:11 PM
01/24/14 08:11 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Did edelbrock ever get the issues resolved with this carb and it's application specs ????
[Re: Hotlumpy]
#1568116
01/24/14 08:51 PM
01/24/14 08:51 PM
RapidRobert
It backfires ONLY at full throttle? & that is in (up thru) all 3 gears right? Part throttle is OK? got another ECU you could borrow for an hour? You might check psi at the carb inlet @ WOT unless you are sure you have enough delivery right now
[Re: Hotlumpy]
#1568120
01/24/14 11:02 PM
01/24/14 11:02 PM
RapidRobert
with the addit'l info I'm thinking it ain't fuel (including the fact that the tank/sending unit was OK with the 318 & that includes carbs after 3 of em). After 3 dizzys I'm thinking not reluctor gap & not likely phasing was way off on all 3 of em. I'm out on a limb but I'm thinking coil or plugs/plug wires/5/7 plug wires switched. Stay in touch. EDIT any possibility of a vac leak
[Re: Hotlumpy]
#1568122
01/25/14 12:55 AM
01/25/14 12:55 AM
RapidRobert
I think we're gonna laugh when (after) we find it! If it's a symmetrical cam (same lobes) you could get the pushrods of #1 or #6 cyl to where both are moving and are at the same height (rockover) & at that point the timing marks should be within several degrees of TDC (varies slightly since the cam could be advanced) but not 10 or 15 off but with this being a part time occurance I'm thinking something else. Stay in touch, this is a toughie. I want this one ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: BulletBob]
#1568127
01/25/14 06:20 PM
01/25/14 06:20 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Hmm, when I bought my 64 300 the timing jumped around a lot, it was a combo of worn out dual point distributor and drive bushing. I will admit the distributor was most of it.
