I was told by Milodon that the A-body one would fit when I asked. The reason I asked was because the stock C-body pan is an easy fix for swapping a BB into an A-body. A C pan has the same idler arm relief in it that a BB A-body needs. I figured it should work in reverse ie use an A-body pan in a C.
They were WRONG...
![](/ubbthreads/images/graemlins/tsk.gif)
Well not completely wrong. It did fit, sort of, if not being able to turn right wasn't an issue.
![](/ubbthreads/images/graemlins/flame.gif)
After we fabbed a notch in the sump so the idler arm had somewhere to go my 7 qt pan is now probably 6.5.
Kevin
