Re: Cast crank pulley versus forged crank pulley
[Re: dweller]
#1567851
01/24/14 11:31 AM
01/24/14 11:31 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
My research indicated that I would be able to reuse the four pulley crank unit from the original motor despite having swapped the crank. Now upon reassembly, it looks like the accessory pulleys are off by a small amount, and I'm not sure whether its due to bracket misalignment or a different pulley depth.
I can say with some confidence it's due to a pulley or bracket reinstalled incorrectly. I have done mix 'n match on these parts between steel and forged crak BB's many times and the spacing is the same and everything will line up. That is, if everything is swapped as one set.
I will also ashamedly admit I once reversed the water pump pulley and.... well, you know the rest.
Cast crank engine now with steel crank: All brackets and pulleys from the cast crank engine.
[Re: dweller]
#1567854
01/25/14 02:14 PM
01/25/14 02:14 PM
Posts: 6,108 Valencia, España
NachoRT74
Valencia, España
I stroked my 400 ( cast assembly ) with 440 forged crank and correct dampener to forged crank with offset hole ( 70s setup ) to reuse my original stock pulley. Everything lined up perfect.
