Advantages of larger cam journal #1567583
01/23/14 02:50 PM
01/23/14 02:50 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Since these new roller cams are going to cost me twice the price,
I was leaning towards a 53 mm cam
What's the advantage over a standard cam journal?
Re: Advantages of larger cam journal [Re: Sammy] #1567584
01/23/14 02:55 PM
01/23/14 02:55 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
Less flex (both in bending and torsion), and you can make the base circle bigger.
Re: Advantages of larger cam journal [Re: Kevins493] #1567585
01/23/14 03:14 PM
01/23/14 03:14 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
Might be good for more lift to i gues !?
Re: Advantages of larger cam journal [Re: Sammy] #1567586
01/23/14 04:20 PM
01/23/14 04:20 PM
I would go with the standard Ford size, which is 55 MM I think The larger journal sizes allow you to have a cam ground with more lift and not have to reduce the size of the base circle or grind the cam in closer to the center of the cam, to get the additional lift EDITED, I'm under the impression that the newer Ford motors come with 55 MMM roller cam bearings, and there not much money to buy them from Ford either I remember Earl Wade telling me years ago(1991 or so)that Ford had the biggest I.D cam bearings of all the U.S. auto makers, his cam in his NSS 427 F.E. 1963 1/2 lightweight Galaxy had over 1.00 lift back then I never got to measure the valve lift at the retainers but I think he had no reason to lie to me about that back then
Re: Advantages of larger cam journal [Re: Cab_Burge] #1567587
01/23/14 05:19 PM
01/23/14 05:19 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
A BBF is 54mm which is a very common babbit bearing size
Monte
Re: Advantages of larger cam journal [Re: Monte_Smith] #1567588
01/23/14 05:29 PM
01/23/14 05:29 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Monte
What size would you need to go to if you wanted to run roller cam bearings?
Jerry
Old Geezer Racing
Re: Advantages of larger cam journal [Re: SCATPACK 1] #1567589
01/23/14 09:55 PM
01/23/14 09:55 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Monte
Jerry
Bring your wallet and take your pick. 65 m.m. , 70 m.m. , 75 m.m.
I am struggling to recall the largest I have read about , but 90 m.m. rings a bell.
Re: Advantages of larger cam journal [Re: SCATPACK 1] #1567590
01/24/14 12:01 AM
01/24/14 12:01 AM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
jesel has roller 54mm bearings
Re: Advantages of larger cam journal [Re: tubtar] #1567591
01/24/14 12:02 AM
01/24/14 12:02 AM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
You can do roller bearings at 55MM. I have a 55MM and 70MM cam both roller bearing
Re: Advantages of larger cam journal [Re: Al_Alguire] #1567592
01/24/14 01:34 AM
01/24/14 01:34 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
You can get roller bearings in 54,55,60 and 70mm, that I know of. 54&55mm cams are not that high. 60 and larger.....bring a big check.........LOL!!!
Monte
Re: Advantages of larger cam journal [Re: Monte_Smith] #1567593
01/24/14 01:53 AM
01/24/14 01:53 AM
Dyno1 Offline
Dyno1  Offline
A simple way to do it is have the front four journals cut to the 429/460 Ford size and leave the rear journal stock Mopar. Comp has cores for this application. Dyno
