2001 Durango 4.7 cold starting problem #1567432
01/23/14 11:26 AM
01/23/14 11:26 AM
Carson City, NV
babarracuda Offline OP
Carson City, NV
My 4.7 dtar5ts hard when it is just off dead cold. First start in the AM great, drive to the market for a couple items and it cranks without trying to start.We hacve tested the fule pump an it gets 60 pounds with three clicks of the ignotion switch. If I press down on the gas, it will start after a few revolutions. I am frustrated. Reset all the error codes (there were none) and it is better but not fixed. HELP!!!
Re: 2001 Durango 4.7 cold starting problem [Re: babarracuda] #1567433
01/23/14 03:44 PM
01/23/14 03:44 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Idle air control Valve in the T-body packed with carbon?
Remove and disassemble the T-body with air intake cleaner. JMHO
When was the last time it had a tune up?
4.7L engines go through plugs and need changed every 30K.
Re: 2001 Durango 4.7 cold starting problem [Re: Todd] #1567434
01/23/14 07:25 PM
01/23/14 07:25 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree with Todd. Clean the throttle body and IAC motor. Ron
