Putty for door panel plastic sheeting #1567328
01/22/14 11:13 PM
01/22/14 11:13 PM
Utah, USA
1964superstock Offline OP
Utah, USA
What type of putty is used to hold the clear plastic sheeting to the door sheet metal and quarter window area?
Also, how thick of plastic sheeting is correct?
A good suggested supplier of both would be appreciated.
Re: Putty for door panel plastic sheeting [Re: 1964superstock] #1567329
01/22/14 11:26 PM
01/22/14 11:26 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Butyl can be used, but the easiest way is 3M spray adhesive, just give the door frame a light coat and stick the plastic to it. I used heave plastic from the hard wear store, and cut it to size.
Re: Putty for door panel plastic sheeting [Re: 1964superstock] #1567330
01/23/14 04:16 AM
01/23/14 04:16 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
The factory used rope caulk for the plastic, plastic is thick like 5 mil. Somebody repos the plastic kits, maybe Detroit Muscle Car Tech.
Re: Putty for door panel plastic sheeting [Re: 1964superstock] #1567331
01/23/14 10:43 AM
01/23/14 10:43 AM
new york usa
P
pattyboy 572 Offline
P
new york usa
Re: Putty for door panel plastic sheeting [Re: pattyboy 572] #1567332
01/23/14 07:18 PM
01/23/14 07:18 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
I'd be interested in get old sets of these if anyone has any. I don't make them but would do my best to make them as accurately as possible.
I know most people just threw them out so they aren't very easy to find.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Putty for door panel plastic sheeting [Re: 71TA] #1567333
01/25/14 08:41 PM
01/25/14 08:41 PM
O
OLD318 Offline
OLD318  Offline
O
You can buy a thicker, almost crystal clear plastic from Joanne's fabric store
that you can cut to fit all the doors/qtr windows for about $10.00...
It will do everything for you that the repro "kit" will for
less than a quarter of the cost.
The vinyl they sell is actually thicker than the original material, very easy to cut, and looks better IMHO.... The original material reminds me of a thick opaque plastic trash bag material...
As far as duplicating the butyl tape...
If you absolutely have to have this, you can use a line of white
auto body sealant that you can get for about $12.00 a tube and can
use from a regular caulk gun...
OR, use the can of spray adhesive ($5-$6) like suggested above...
I personally like the spray adhesive better.... but that's a personal perference...
Just my 2
Best of luck to all...
Re: Putty for door panel plastic sheeting [Re: OLD318] #1567334
01/26/14 12:40 AM
01/26/14 12:40 AM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
Not sure what year they started it but some of the factory strip caulk {dum-dum as some call it}I've run into has a backer{wire or thin rope} in it to keep it from stretching too far...I prefer the factory style caulk over glue in case you ever need back in there...
Re: Putty for door panel plastic sheeting [Re: screamindriver] #1567335
01/26/14 12:46 PM
01/26/14 12:46 PM
WNY
slimert Offline
slimert  Offline
WNY
I used a product that 3M made. Came in a flat box, you would pull 1/4" x 10" strips of white rope caulk 'dum-dum'. Reused most of the factory rope caulk. Not really sure what's correct, looked like the passenger door on the had spray on adhesive from the factory and the other 3 panels had white rope caulk.
Re: Putty for door panel plastic sheeting [Re: slimert] #1567336
01/26/14 05:45 PM
01/26/14 05:45 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
"MoreTite" is the brand my Dad used back in the day. I was happy to find it still available at my local Ace Hardware store when I needed some for the same application as you.
Sticks nicely to the sheet metal. Holds but also releases the plastic cleanly when you need to open it up.
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Putty for door panel plastic sheeting [Re: 67SATisfaction] #1567337
01/26/14 07:15 PM
01/26/14 07:15 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
3M ribbon weld (wound ribbon sealer) come's in different diameters
I have gotten it at Advance Auto and Summit Racing
The only caution is I have NEVER had to go back in a door I have used it on so I don't know how it releases
Re: Putty for door panel plastic sheeting [Re: SSAAHemiFan] #1567338
02/02/14 08:44 PM
02/02/14 08:44 PM
beepilot Offline
beepilot  Offline
When I restored my 71 Bee about 10 years ago I used plumbers mastic or whatever it was called.... It seemed about the same color and texture as what I scraped off. It can rolled and shaped as necessary. And for the plastic I used vapor barrier from any local building supply store. I didn't really know how the plumbers mastic was going to work out, but I had the panels off recently and I was pleased it held up nicely, I could peel the plastic off and reapply.
