Oil on plug =/ #1567147
01/22/14 06:05 PM
01/22/14 06:05 PM
Sweden
Mopar Guy Offline OP
Sweden
I just pulled out the plugs on my six pack rb engine and discoverd that the number 8 cylider plug had oil burnt in to it.... What could cause this ? I remember refilling some more oil in the engine this year so i whas thinking maybe the pcv valve whas the issue becas i have no shield for in in the valve cover and shore the number 8 is close to the inlet of the center carbs inlet for the pcv but then i should have had more than that plug whit oil on it Can it be a piston/ring damedg on just one cylinder.... or the intake gasket leak on just that one or the valve seal going bad on that only or the plug going bad ???? Pleas give me your experience guyīs !!!!!!!!
Re: Oil on plug =/ [Re: Mopar Guy] #1567148
01/22/14 08:46 PM
01/22/14 08:46 PM
Baltimore,MD
Bill_LBSR Offline
Bill_LBSR  Offline
Baltimore,MD
Could be a bad valve seals, sucking oil past the intake gasket, piston rings or even a cracked intake port. The first two would be the easiest to check for.
LBSR
Re: Oil on plug =/ [Re: Mopar Guy] #1567149
01/23/14 05:47 AM
01/23/14 05:47 AM
Put a baffle( at least covering one inch each side of the valve itself ) under the PVC hole first Then do a leak down test or put a new plug in that hole and go drive it softly for 20 to 30 kilometers, no WOT Then look at the plug when you get back If it is still oil soak look deeper
Re: Oil on plug =/ [Re: Cab_Burge] #1567150
01/23/14 12:11 PM
01/23/14 12:11 PM
Sweden
Sweden
Cab i did a cylinder leak down test on that 8 cylinder whit the oil folded plug (cold engine) and i had 25% leak and also tested nr 4 whith same result so i gues i can ruel out a piston/ring damedg now
I will cover the pcv valve inside the valve cover as you surgest and i whas going to do that anyway and put in new plugs and see what it looks like after a test drive later on this year becas a have alot of snow around me right now Thanks for the tipīs
Re: Oil on plug =/ [Re: Mopar Guy] #1567151
01/23/14 02:08 PM
01/23/14 02:08 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
When I ran one I used the Ford type breather w/the foam and pcv valve inside of it to get more distance and was better than the pcv shoved in the v-cover...............
Re: Oil on plug =/ [Re: Thumperdart] #1567152
01/23/14 02:28 PM
01/23/14 02:28 PM
Sweden
Sweden
Do you have any pic to show me on that ? Ive never lookt that close at a Ford before but mabe itīs time to do that then
Re: Oil on plug =/ [Re: Mopar Guy] #1567153
01/23/14 02:50 PM
01/23/14 02:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No I don`t just go to napa or wherever and ask for a Ford breather/pcv valve set up and you should be good 2 go.............
Re: Oil on plug =/ [Re: Thumperdart] #1567154
01/23/14 03:10 PM
01/23/14 03:10 PM
Sweden
Sweden
That will be tricky you see i live veary far from any Napa store as whe dont have them here in Europe i will visit CA in April so maybe then i can go to Napa ! I tryed looking on ebay but they only have s short strait metal pcv valve showing for Ford
Re: Oil on plug =/ [Re: Mopar Guy] #1567155
01/23/14 03:23 PM
01/23/14 03:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Call me when you`re here if ya need any help..........760-900-3895........
Re: Oil on plug =/ [Re: Thumperdart] #1567156
01/23/14 04:11 PM
01/23/14 04:11 PM
Sweden
Sweden
Call me when you`re here if ya need any help..........769-900-3895........
I have sent you a message !!!!
Re: Oil on plug =/ [Re: Thumperdart] #1567157
01/23/14 04:17 PM
01/23/14 04:17 PM
Me thinks the area code may be wrong Dang them old phone guys
Re: Oil on plug =/ [Re: Cab_Burge] #1567158
01/23/14 07:10 PM
01/23/14 07:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Just caught that............
