Rings gap - 150 shot #1566627
01/21/14 10:50 PM
01/21/14 10:50 PM
Sao Paulo, Brazil
dart_73_br Offline OP
Sao Paulo, Brazil
Hello guys,
Need a help..
318 will run on ethanol + 150 shot..
Some ring makers says 0.0055" x bore size for 1st and 2nd rings....
But saw in a nitrous forum that should use a bigger gap in 2nd ring..
Cold you please give me your opinion...?
Thanks,
Re: Rings gap - 150 shot [Re: dart_73_br] #1566628
01/21/14 11:05 PM
01/21/14 11:05 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
With a 4.440" bore this is how much I changed them for a healthy shot.
Top ring gap (N/A) .020
Top setting .032
2nd ring gap (N/A) .016
2nd setting .036
Re: Rings gap - 150 shot [Re: dart_73_br] #1566629
01/22/14 02:16 AM
01/22/14 02:16 AM
A lot wider is way better than a tiny bit to narrow, especially on NOS
Re: Rings gap - 150 shot [Re: dart_73_br] #1566630
01/22/14 12:42 PM
01/22/14 12:42 PM
Az
Crizila Offline
Crizila  Offline
Az
Hello guys,
Need a help..
Thanks,
IMO, that aint gonna be enough. Follow the piston mfg's recommendations - and add another 3 - 4 thou to be safe.
Fastest 300
Re: Rings gap - 150 shot [Re: Crizila] #1566631
01/22/14 12:47 PM
01/22/14 12:47 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
it also depends on piston material.
forged aluminum has a different causation than
Hypereutectic pistons. i would look into what
your piston manufacturer recommends as well..
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Rings gap - 150 shot [Re: cheapstreetdustr] #1566632
01/22/14 01:09 PM
01/22/14 01:09 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
Itīs KB KB399 hypereutetic one...
Iīve mailed their tech support but no answers so far... using moly rings with the hyper pistons...
Re: Rings gap - 150 shot [Re: dart_73_br] #1566633
01/22/14 01:34 PM
01/22/14 01:34 PM
i think the hypers end up with top ring gap at 25
i dont have my notes handy on that build...
KB will tell you the correct amount for sure.
[image][/image]
Re: Rings gap - 150 shot [Re: cheapstreetdustr] #1566634
01/22/14 01:38 PM
01/22/14 01:38 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
Found in their hyper catalog...
street nitrous:
TOP ring factor = 0.008 > 3.94 x 0.008 = 0,0315"
SECOND ring = 0.004 x bore > 0,0157"
I think thatīs it...
Re: Rings gap - 150 shot [Re: dart_73_br] #1566635
01/22/14 03:28 PM
01/22/14 03:28 PM
street nitrous:
No way in the world would I run the second ring that tight with your motor, maybe .031 or larger Most of the piston ring makers and the piston makers use to recommend numbers like that years ago, not now Almost all of the better companys recommend a bigger gap on the second ring than the top ring now The reason being is ring flutter at the upper RPM in a race motor
Re: Rings gap - 150 shot [Re: dart_73_br] #1566636
01/22/14 07:20 PM
01/22/14 07:20 PM
Toronto
mshred Offline
mshred  Offline
Toronto
street nitrous:
That number for the second ring seems too tight to me, even on motor.
I followed my ring manufacturers instructions when gapping mine for the nitrous, and it recommended a larger ring gap up top then for the second ring...Then I posted about my gaps on another board, and was told by a bunch that the second ring gap should be bigger then the first to allow the trapped gases to escape.
I would say gap them larger then you actually want to spray, because you are going to want more pill size after a while, and the larger gaps really shouldn't hurt anything...but seeing your running hypers, I wouldn't push them too much...I'd be more comfortable spraying cast then hyper pistons, but thats just me.
Re: Rings gap - 150 shot [Re: mshred] #1566637
01/22/14 08:16 PM
01/22/14 08:16 PM
street nitrous:
Hypertitics(SP?) are cast pistons, they are not forged I'll bet you meant forged pistons for all out racing on NOS or any other power adder, yes?
Re: Rings gap - 150 shot [Re: Cab_Burge] #1566638
01/22/14 10:43 PM
01/22/14 10:43 PM
Toronto
mshred Offline
mshred  Offline
Toronto
street nitrous:
No, I meant what I said cab lol...As far as I know, cast and hypers are made from slightly different processes...I know both are touchy, but have always been warned that hypers are even more so and when they let go, it's a little nastier (although at that point, pain is pain lol).
Of course, I could be all wrong...I have only ever sprayed a forged motor- it was a safety net for an idiot like me lol
Re: Rings gap - 150 shot [Re: Cab_Burge] #1566639
01/22/14 10:45 PM
01/22/14 10:45 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Hyper and moly rings not best choices for nitrous.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Rings gap - 150 shot [Re: 1967dartgt] #1566640
01/22/14 11:02 PM
01/22/14 11:02 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
150 is not that much... But, most people who intend to run 150 end up with more.
NO WAY IN HADEES I would run that gap on a second ring. But, that said I do not follow the flock with the larger ring gap on the second ring. The idea is whatever gets below the top ring should have extra room to get by the second. Ring flutter comes from pressure between the rings. Keep it up and eventually you put so much pressure between them with a little heat in the valve pocket and you lift the land. The top ring will always see more heat than the second. Which equals more ring expansion in the top ring. I set my gaps the same but, ran fairly large gaps.
Leon
Re: Rings gap - 150 shot [Re: Leon441] #1566641
01/22/14 11:15 PM
01/22/14 11:15 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
The one thing to add is typically top ring and second ring are not the same material. 2nd ring is usually cast with a "good" top ring, be it Moly, or whatever.
Re: Rings gap - 150 shot [Re: Bigcube] #1566642
01/22/14 11:20 PM
01/22/14 11:20 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
Guys, this juice stuff might be addictive but I know this hyper are crap for large nitrous shot so thats why I'm limiting it to 150. And thats what I have now.. So... Will put it together and have some fun....
1973 Brasilian Dart
E100, boosted 390"
Re: Rings gap - 150 shot [Re: dart_73_br] #1566643
01/22/14 11:40 PM
01/22/14 11:40 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Correction: not MIGHT be addictive but WILL be addictive.
Take it from me, especially if you have the pistons out and have not balanced them yet...Sell your pistons and rings, get a forged piston and non moly rings and put them in with a gap that is sufficient for say a 200-250 hit....When the addiction kicks in, you'll be glad you did it
Just my ...good luck and have fun with it regardless !
Re: Rings gap - 150 shot [Re: Cab_Burge] #1566644
01/22/14 11:45 PM
01/22/14 11:45 PM
Az
Crizila Offline
Crizila  Offline
Az
street nitrous:
Both those #s are a little tight, but hypers have an expansion chamber between the top and second rings to address ring flutter. I have run those style pistons with .034 on the top ring and .017 on the second ring with no problems, A 150 shot will work with those pistons if you go easy on the timing and run it cold as you can - water injection, etc.
Fastest 300
Re: Rings gap - 150 shot [Re: Crizila] #1566645
01/22/14 11:55 PM
01/22/14 11:55 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I used to run the KB hyper pistons in a 360 back in the 90's. I gapped the rings for nitrous like the instructions said . I never ran less than 150 shot and ran 175 some times. I had the kb 107's and J-heads. I always ran about 28* timing and 93 octane fuel.Never had any problems...
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
