big exhaust systen on higher hp car??? #1565919
01/20/14 01:04 AM
01/20/14 01:04 AM
Chesterfield Twp. Mi.
John Burdine Offline OP
I'm going to build a 4" exhaust system for the Demon with a straight threw style race muffler and it will have tail pipes to the bumper. I'm going to use turbo clamps so I can remove it and slam bullet mufflers on the collectors for at the track. I would still like the exhaust system to flow as good as possible.
my question is, is an x-pipe worth all the bends it takes to install one. I thought the school of thought was exhaust likes as few bends as possible.
so, I'm need to decide to either run an x-pipe, or run the pipe straight to the muffler (maybe a balance tube) the out the tails.
Re: big exhaust systen on higher hp car??? [Re: John Burdine] #1565920
01/20/14 01:07 AM
01/20/14 01:07 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Do you plan to run tailpipes out to the rear bumper ?
Never mind as I see where I missed that. Dont know how much room you have but are you planning to downsize the tailpipes to maybe 3" ? Ron
Re: big exhaust systen on higher hp car??? [Re: John Burdine] #1565921
01/20/14 01:13 AM
01/20/14 01:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
John... if you can get the muffs at the bumper it
helps due to the exhaust being cooler back there...
if you run a X pipe they do work BUT its suppose to
be 1/2 way from the end of the primaries to the muffs
or the expansion point(if no muffs are used)... A
H-pipe you put at the end of the collectors(or close
to the primaries)
Re: big exhaust systen on higher hp car??? [Re: MR_P_BODY] #1565922
01/20/14 01:19 AM
01/20/14 01:19 AM
is the x-pipe worth the extra bends?
Re: big exhaust systen on higher hp car??? [Re: John Burdine] #1565923
01/20/14 01:27 AM
01/20/14 01:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes.. it does add HP to a system with muffs... if it
has back pressure... so if you run a straight thru
muff MAYBE you dont want the X.... its your choice
based on back pressure... all it does is kick pulses
back and forth
Re: big exhaust systen on higher hp car??? [Re: John Burdine] #1565924
01/20/14 01:28 AM
01/20/14 01:28 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IMO yes an X pipe is worth it. Will even quiet the car down a good deal. IF you have the room.
Re: big exhaust systen on higher hp car??? [Re: MR_P_BODY] #1565925
01/20/14 01:32 AM
01/20/14 01:32 AM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
A friend of mine that runs a 7 sec true ten five n/a combo has a shop with a chassis dyno.He has tried everything and said on a car like yours a h pipe makes more power.Now on like a mustang or a car that runs 11 or 12's he said a x pipe has made more power.hope this helps.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: big exhaust systen on higher hp car??? [Re: bdaz smblk] #1565926
01/20/14 01:38 AM
01/20/14 01:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would say that his data was with some type of muffs
(with the 11-12s car) which again is a back pressure
thing... I like the H-pipe myself but it has to be
up close to the engine(primaries) to be efficient
Re: big exhaust systen on higher hp car??? [Re: John Burdine] #1565927
01/20/14 03:23 AM
01/20/14 03:23 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I think the X is a bit quieter than an H pipe system. Not sure how it is for power, but 4" is going to take a lot of room under the car. I had 3-1/2" on my car with straight through mufflers and it was way too loud for the street, but sounded good at the track.
Re: big exhaust systen on higher hp car??? [Re: 451Mopar] #1565928
01/20/14 06:54 AM
01/20/14 06:54 AM
I don't care if its quieter, just want what whichever will cost the least hp.
Re: big exhaust systen on higher hp car??? [Re: John Burdine] #1565929
01/20/14 09:49 AM
01/20/14 09:49 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You have to pay close attention to how the x merge is made. If the two pipes are merged to close together it will defeat to purpose and cause a lot of restriction.
Mopar to the bone!!!
Re: big exhaust systen on higher hp car??? [Re: 72Swinger] #1565930
01/20/14 01:17 PM
01/20/14 01:17 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Vizard did a recent article for Pop hot rodding where he said anything over 2.2cfm per horsepower doesn't gain you anything (but extra weight).
Mainatining Velocity away from the exhaust valve and minimal downstram restrictions are at least AS important as OD. FAST guys are going high 9's with full dual 2 1/2" exhausts and Factory casting exhaust manifolds (obviously ported but still not as good as a race header)....that's pretty telling to me.
WIZE
In Car:
Re: big exhaust systen on higher hp car??? [Re: MR_P_BODY] #1565931
01/20/14 08:29 PM
01/20/14 08:29 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
Both his test were with muffs.He has to run them in the class he runs.
Re: big exhaust systen on higher hp car??? [Re: bdaz smblk] #1565932
01/21/14 08:50 AM
01/21/14 08:50 AM
pa
572charger Offline
572charger  Offline
pa
ive got 4 1/2 inch threw a set of top ten flowmasters and back to the bumper tail pipes no crossover or x pipe car runs the same with the 80 +lb exhaust on or off 9.60s at 140+ its not quiet but then again its hard to make 600cubes quiet !!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: big exhaust systen on higher hp car??? [Re: 572charger] #1565933
01/21/14 09:56 AM
01/21/14 09:56 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
When I was running 9.80's with a 3.5" exhaust I added an x-pipe and it made the car sound really nice, and didn't slow it down one bit, system weighed about 75 pounds and the car ran a couple hundredths quicker and a tiny bit more mph than open headers.
Re: big exhaust systen on higher hp car??? [Re: ProSport] #1565934
01/22/14 01:52 AM
01/22/14 01:52 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I have the Pypes 3.5 X-pipe kit.
Re: big exhaust systen on higher hp car??? [Re: gsmopar] #1565935
01/22/14 09:06 AM
01/22/14 09:06 AM
nielsville, minn.
Q
quickd100 Online content
quickd100  Online Content
Q
nielsville, minn.
I run a 3-1/2" system, X-pipe, 3-1/2" ultra-flows. I set it up like that when I built my 528 Hemi and it made more hp without the pipes on. By the time I built my 605 I had a dyno and tested the motor with and without the exhaust system in place. The 3-1//2" system cost 117hp and 97ftlbs on my 605. I can live with that though as hooking that much power on the street isn't going to happen anyway.Dave
Re: big exhaust systen on higher hp car??? [Re: quickd100] #1565936
01/22/14 09:54 AM
01/22/14 09:54 AM
K
kielbasa Offline
kielbasa  Offline
K
WOW, that seems like a HUGE loss!!!!!!!!!
Re: big exhaust systen on higher hp car??? [Re: kielbasa] #1565937
01/22/14 01:30 PM
01/22/14 01:30 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Big Hemi's are a different ball game, they sometimes don't like an exhaust system.
Some guys make them work though, such as 572Charger.
Re: big exhaust systen on higher hp car??? [Re: ProSport] #1565938
01/22/14 01:46 PM
01/22/14 01:46 PM
an8sec70cuda Offline
Mine doesn't like mufflers. I still use my 4" H pipe system on the street, but at the track I put my short 4" bullets right on the collectors.
CHIP
'06 GMC 2500HD LBZ Duramax
