Does anyone out there have a picture of the plug end of the turn signal switch for a 67-69 Dart? I replaced my switch and replaced the wires in the bulk connector and somewhere I got one or two or three wrong. The horn works. The left turn signal works for about 4 blinks then stops. The right will blink for about 4 times, some times. Then other times it won't blink at all. You will actually hear the flasher relay stop making noise. The 4-ways, only the left tail light blinks. As usual the replacement switch had two or three wires that were not exact matches to the original wires, so I more less guessed.
