insulation nails/pins #1564675
01/17/14 09:00 PM
01/17/14 09:00 PM
Harrisburg, Pa.
screamindriver Offline OP
Harrisburg, Pa.
Any current source for the 62-65 short insulation nails ??? thanks..
Re: insulation nails/pins [Re: screamindriver] #1564676
01/19/14 06:05 AM
01/19/14 06:05 AM
California, USA
filmsurgeon Offline
filmsurgeon  Offline
California, USA
Detroit Muscle Technologies (DMT)?
Re: insulation nails/pins [Re: filmsurgeon] #1564677
01/19/14 04:29 PM
01/19/14 04:29 PM
Harrisburg, Pa.
Harrisburg, Pa.
DTM was going to tool up for the shorter pins...Not sure if that's going to happen with the current downward spiral of the hobby...The repops are the more common 66-up{longer} versions... I did'nt want to put the snowshoes on and make the boneyard trip this time of year but..
Re: insulation nails/pins [Re: screamindriver] #1564678
01/20/14 09:14 PM
01/20/14 09:14 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
They are in the works. 4-6 weeks out. I needed them to work with the new firewall insulation and kickpanel product line I'm working on.
I originally redid the more common longer pin cause those were as hard as a rock and I heard many complaints. People said they had to drill open the firewall holes to install them. Ours are the same firmness/fl;exibility as OEM.
Will also be offering the short rubber pins/nails for the 73 and 74 firewall insulations. Doubt we'll do the rubber covered shoddy insulation found on the 75 and up Mopars but I never say never.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: insulation nails/pins [Re: 71TA] #1564679
01/20/14 10:23 PM
01/20/14 10:23 PM
Harrisburg, Pa.
Harrisburg, Pa.
Thanks Jim...If they're only 4-6 weeks out I can work that around this project...I need at least two sets...I'll give you a ring...
