Page 3 of 5 1 2 3 4 5
Re: 61 Plymouth twin turbo longram project [Re: dragula426] #1564198
06/17/14 05:46 PM
06/17/14 05:46 PM
duluth mn.
dragula426 Offline OP
duluth mn.
putting stuff together
Re: 61 Plymouth twin turbo longram project [Re: dragula426] #1564199
06/17/14 05:47 PM
06/17/14 05:47 PM
duluth mn.
duluth mn.
mocking up interior stuff
Re: 61 Plymouth twin turbo longram project [Re: dragula426] #1564200
06/17/14 05:48 PM
06/17/14 05:48 PM
duluth mn.
duluth mn.
some more
Re: 61 Plymouth twin turbo longram project [Re: dragula426] #1564201
06/17/14 05:49 PM
06/17/14 05:49 PM
duluth mn.
duluth mn.
door panels fitted
Re: 61 Plymouth twin turbo longram project [Re: dragula426] #1564202
06/17/14 05:53 PM
06/17/14 05:53 PM
duluth mn.
duluth mn.
yes, i'll be painting the armrest bases!
Re: 61 Plymouth twin turbo longram project [Re: dragula426] #1564203
06/17/14 05:55 PM
06/17/14 05:55 PM
duluth mn.
duluth mn.
just about all of the engine stuff is fitted/ mocked up & ready for paint. then it's off to the dyno
Re: 61 Plymouth twin turbo longram project [Re: dragula426] #1564204
06/17/14 05:56 PM
06/17/14 05:56 PM
duluth mn.
duluth mn.
x
Re: 61 Plymouth twin turbo longram project [Re: dragula426] #1564205
06/17/14 05:56 PM
06/17/14 05:56 PM
duluth mn.
duluth mn.
y
Re: 61 Plymouth twin turbo longram project [Re: dragula426] #1564206
06/17/14 05:57 PM
06/17/14 05:57 PM
duluth mn.
duluth mn.
we have paint on a few things
Re: 61 Plymouth twin turbo longram project [Re: dragula426] #1564207
06/17/14 05:58 PM
06/17/14 05:58 PM
duluth mn.
duluth mn.
1 more..... I got to roll it outside finally
Re: 61 Plymouth twin turbo longram project [Re: dragula426] #1564208
06/17/14 07:08 PM
06/17/14 07:08 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Do builds get any better?
Unique, full of imagination, I love it.
CrAzYMoPaRGuY
Re: 61 Plymouth twin turbo longram project [Re: CrAzYMoPaRGuY] #1564209
06/18/14 11:17 AM
06/18/14 11:17 AM
duluth mn.
duluth mn.
Thanks!
Re: 61 Plymouth twin turbo longram project [Re: dragula426] #1564210
06/18/14 06:08 PM
06/18/14 06:08 PM
Minnesota
peabodyracing Offline
Minnesota
Wow, just Wow. That is impressive. I envy your talents.
Lead, follow or get the hell out of the way
Re: 61 Plymouth twin turbo longram project [Re: peabodyracing] #1564211
06/19/14 01:51 AM
06/19/14 01:51 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
This is going to be one Bad @$$ car!
Re: 61 Plymouth twin turbo longram project [Re: dragula426] #1564212
06/22/14 07:13 PM
06/22/14 07:13 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So I'm thinking over the weekend about the comment of the turbo plumbing hiding the look of the long rams. And then I'm thinking you are trying to balance pre butterfly boost pressure, and the OEM balance tube would not be effective for that. Then I realize to a some what degree, you have the left bank exhaust turbo supercharging the right bank intake. Of course that ultimate effect is dependent on your intake X balance design.
So Is this a potential and/or significant issue?
What if the turbo outs were plumbed ea in one big 90 bend back to the other side throttle body, with slight overlapping ea other as they exit the turbos, and in that overlap area, have a less robust balance junction, since less balancing is needed?
Or should I just butt out.
Re: 61 Plymouth twin turbo longram project [Re: dragula426] #1564213
06/22/14 11:03 PM
06/22/14 11:03 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
Love the car. I still have a video clip of it going down Brice. I see you changed the license plate from the one you had on it when it was supercharged This is one of my all time favorite Mopars. You sir have awesome hotrodding skills.
Re: 61 Plymouth twin turbo longram project [Re: HEMIDOG 70] #1564214
07/22/14 01:51 AM
07/22/14 01:51 AM
duluth mn.
duluth mn.
getting closer!
final blocking & touch-ups done
Re: 61 Plymouth twin turbo longram project [Re: dragula426] #1564215
07/22/14 01:51 AM
07/22/14 01:51 AM
duluth mn.
duluth mn.
Re: 61 Plymouth twin turbo longram project [Re: dragula426] #1564216
07/22/14 01:52 AM
07/22/14 01:52 AM
duluth mn.
duluth mn.
22
Re: 61 Plymouth twin turbo longram project [Re: dragula426] #1564217
07/22/14 01:53 AM
07/22/14 01:53 AM
duluth mn.
duluth mn.
33
