Re: Engine Paint
[Re: TX9AAR]
#1564021
01/19/14 11:04 PM
01/19/14 11:04 PM
Posts: 153 Illinois
v10
Illinois
Has any one used Eastwood Ceramic Engine paint?
Bump for this.......has anyone used this paint???
Re: Engine Paint
[Re: v10]
#1564022
01/20/14 10:34 AM
01/20/14 10:34 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
I said......
One for Eastwood out of the can, here.
Maybe you're a visual type of guy.
Brushed on from a qt. can: Eastwood ceramic requires a hardener.
Re: Engine Paint
[Re: Silver70]
#1564024
01/22/14 12:12 AM
01/22/14 12:12 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I used eastwoods ceremic paint with hardened mixed in. Sprayed with HVLP.
Looks great, doesn't fade or stain. But it's brittle. If you take your engine apart for an intake swap, head swap, water pump change etc, the paint will crack and flake off the hardware.
Otherwise, looks great and I'm happy with it. Haven't found a spray bomb yet that doesn't stain or lift when gas, oil, or antifreeze hits it. The eastwoods stuff wipes right off like the BC/CC on a modern car
**Photobucket sucks**
