best way to get old paint off a dash insert panel. #1563656
01/15/14 07:06 PM
01/15/14 07:06 PM
Maryville TN
68528hemi Offline OP
Maryville TN
i have a 1968 charger and going to re do the dash panel insert. What is the best way to srip off the old paint. and what type of paint to reuse.I would be ok using the same factory color paint.
Re: best way to get old paint off a dash insert panel. [Re: 68528hemi] #1563657
01/15/14 09:13 PM
01/15/14 09:13 PM
IN
ahy Offline
ahy  Offline
IN
If its plastic, I'd clean it thoroughly and repaint using the SEM 3 step system (cleaner/adhesion promoter/paint). I get it from Eastwood.
If it is metal, aircraft stripper, clean then sand/prime/paint with whatever you like including exterior paint.
Re: best way to get old paint off a dash insert panel. [Re: ahy] #1563658
01/15/14 09:41 PM
01/15/14 09:41 PM
Maryville TN
Maryville TN
yes it is plastic.
Re: best way to get old paint off a dash insert panel. [Re: 68528hemi] #1563659
01/16/14 12:31 AM
01/16/14 12:31 AM
Alberta
rustbuckett68 Online content
rustbuckett68  Online Content
Alberta
I've used the old style "Easy Off" aerosol spray oven cleaner on lots of models, and it gets most of the paint off. Using a toothbrush style brush helps. Spray, soak for a hour or so, and wash off (rinse real well). As always, try whatever chemical you use on the backside (a small patch) to see if the plastic is compatible. I found brake fluid would soften some plastics in a hurry!
Re: best way to get old paint off a dash insert panel. [Re: 68528hemi] #1563660
01/24/14 06:12 PM
01/24/14 06:12 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
I used this water based, solvent free product I found at Lowes to strip the paint from a bezel. It left the vacuum plating underneath intact.
Re: best way to get old paint off a dash insert panel. *DELETED* [Re: 68528hemi] #1563661
01/24/14 06:14 PM
01/24/14 06:14 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Post deleted by 70Duster440
Re: best way to get old paint off a dash insert panel. [Re: 70Duster440] #1563662
01/31/14 07:43 PM
01/31/14 07:43 PM
Maryville tn
67coronetman Offline
Maryville tn
Interesting that is good to know i think i will give it a shot.
[image]http://4.bp.blogspot.com/_Cc2CnFp8cJQ/TOQvCqqTJ8I/AAAAAAAAACk/rZKGaB4sWYw/s400/StrippedBezel.jpg][/image]
Old car are me......
