Console mounting brackets
#1563163
01/14/14 01:17 PM
01/14/14 01:17 PM
Posts: 4,437 Omaha Nebraska
Brian_wo
Omaha Nebraska
Any chance the console mounting brackets from a 66 charger will work to mount a factory GTX console in my belvedere?
Seems like a lot parts from the 66 and on newer cars I thought I only remembered there being two pieces.
who is that guy?
Re: Console mounting brackets
[Re: Brian_wo]
#1563165
01/16/14 04:01 AM
01/16/14 04:01 AM
Posts: 28 America
bambi
America
http://www.amazon.com/66-70-Mopar-B-Body-Console-Bracket/dp/B00GCUR7TY SHOULD all be the same. They only sell one set for all the years. Hope this helps. I'm a Gothenburg boy. lol. I am changing my 67 Coronet from a column mount to a floor mount/console. I have a chunk of floor with the brackets on it to use as reference. They appear to be all the same. 3 mounts. I have an end plate from a c-body. They used the same console. It looks the same as every other end cap, but has open slots instead of being all solid, so one can have footwell lights shining through, (the way the factory did it) and also has a cigarette lighter mounted in the middle of it. Just a cool touch, and it all looks original because it is original. Just not on lower class cars. You can also add a trunk release mechanism that came on a bazillion Mopars. Just bolt it on, and run a power wire to it, and place a button where ever you want. It's all factory and fits and works fine. EBay has them all day long. It's modifying, yet it's factory. lol.
[Re: bambi]
#1563166
01/16/14 10:22 AM
01/16/14 10:22 AM
Brian_wo
Omaha Nebraska
Amazon really does sell everything.
I have GTX buckets and console to go in my 67 Belvedere,should look great.
Thanks for the reply.
who is that guy?
[Re: bambi]
#1563167
01/17/14 03:17 PM
01/17/14 03:17 PM
Posts: 2,926 Calgary, Alberta Canada
a12rag
Did the swap on the end piece from a C Body, on my 1970 Sport Satellite. Looks factory (well, really it is !!) and you get added bonus of lighting up the rear footwell area and getting a second power point (cigeratte lighter) . . . Quote:
