4bbl Shaker mounting feet location #1562869
01/13/14 08:21 PM
01/13/14 08:21 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Can any tell me where the feet are positioned when they contact the engine off of a shaker 4bbl baseplate? We are talking a Challenger with a 440. Photos would be great if you have them.
Thanks!!!
1970 Dodge Challenger T/A
Re: 4bbl Shaker mounting feet location [Re: jeff968] #1562870
01/13/14 10:47 PM
01/13/14 10:47 PM
MD
floyd Online content
floyd  Online Content
MD
Jeff - We'll have to see if Terry McCann checks in, but I think 440-4bbls didn't have feet.
Re: 4bbl Shaker mounting feet location [Re: floyd] #1562871
01/13/14 10:53 PM
01/13/14 10:53 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
SHAKER BASE FEET.....WHERE DO THEY GO?
posted July 21, 2008
If I could figure out how to pull it up and give you a link I would.... I was just happy I found the post!
Re: 4bbl Shaker mounting feet location [Re: 6pkaar] #1562872
01/14/14 01:12 AM
01/14/14 01:12 AM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Search only goes back 2 years. 440 4bbl would have to use feet too as the scoop starts to spin without them. Not exactly the desired "shaker" effect.
Re: 4bbl Shaker mounting feet location [Re: jeff968] #1562873
01/14/14 10:24 AM
01/14/14 10:24 AM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
In "key word" put shaker base feet. In date range put newer than 6 years, older than 5 years. It's on the second page "SHAKER BASE FEET....WHERE DO THEY GO" There are measurements on one of the drawings.
Re: 4bbl Shaker mounting feet location [Re: 6pkaar] #1562874
01/14/14 10:33 AM
01/14/14 10:33 AM
MD
MD
you can also google "shaker feet" and "moparts" and find many old posts that way.
You will find some discussions on the lack of feet for 440 4bbl cars.
I also emailed Dave West last night about his original 440 4bbl shaker car and got this response: "....my shaker baseplate is the original and did not have the feet...and the only other 4 bbl shaker car that i know off never had feet either."
Re: 4bbl Shaker mounting feet location [Re: 6pkaar] #1562875
01/14/14 11:30 AM
01/14/14 11:30 AM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
No matches
Re: 4bbl Shaker mounting feet location [Re: jeff968] #1562876
01/14/14 11:29 PM
01/14/14 11:29 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I saved it here you go...Thanks again to Terry for posting the info... But as suggested I'd double check on wether you should add them or not for your application...
Re: 4bbl Shaker mounting feet location [Re: screamindriver] #1562877
01/15/14 01:04 AM
01/15/14 01:04 AM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Thanks very much!!!
Re: 4bbl Shaker mounting feet location [Re: jeff968] #1562878
01/15/14 01:12 AM
01/15/14 01:12 AM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
AFAIK there are no feet/brackets on the 440-4bbl shaker baseplate
The drawing above is for the 6-pack base which used the same style of 'feet' as the Hemi
Re: 4bbl Shaker mounting feet location [Re: YYZ] #1562879
01/15/14 01:25 AM
01/15/14 01:25 AM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Understood, and the number of factory 440 4bbl shaker cars must be less then 10 so they are rare, If no feet then what keeps the scoop from spinning?
Re: 4bbl Shaker mounting feet location [Re: jeff968] #1562880
01/15/14 02:04 AM
01/15/14 02:04 AM
Ontario, Canada
mccannix Online content
mccannix  Online Content
Ontario, Canada
Thats an oldie Colin provided of a crude sketch of as Vlad says, 6 pak feet brackets.
440-4v did in fact not have feet brackets installed when the vendor manufactured them for Chrysler.
While it is true they were for stability I would not go so far as to say say they were to keep the scoop from spinning.
If your base is original does it by chance have a strip of orange paint on it by the carb neck?
440-4v base is same base as a 71 340 base less the feet brackets.
That is why there were separate part numbers for each of those bases.
