Big Block Engine Mounts #1562440
01/12/14 11:48 PM
01/12/14 11:48 PM
NY
Beep Beep Offline OP
NY
I am trying to install a set of Schumacher Poly Locs on a Big Block. I have been fighting with these mounts for hours. I originally used a stock set with a torque strap behind 530hp. I never broke the drivers side but I noticed the passenger side was starting to tear along the part were they mold it to the metal. The mount was still okay but I figured I would replace them with a set of Poly Locs. I installed them and removed the torque strap. I can't get the passenger side to sit flat on the k-member. The driver side is resting on the k-member properly. If I get the passenger side to sit flat on the k-mount the transmission poly mount will not line up and the transmission tail shaft it not centered to the hump in the floor. If I force it to the drivers side with a piece of wood it pulls the passenger side mount off the k-member and no longer sits flat. I am ready to go back to the stock mounts. Can anybody shed some light on this issue.
Re: Big Block Engine Mounts [Re: Beep Beep] #1562441
01/13/14 12:16 AM
01/13/14 12:16 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Maybe not helpful to your situation, but are the Poly Lock types thicker than your original mounts?
I considered the Poly Locks but thought that they would aggravate my already dicey hood clearance issue.
I looked at some parts store replacement mounts and found that they appeared to be about 1 1/8" to 1 1/4" thick. The mounts in my car are thinner than that by a noticeable amount. My LH side is an interlocking type and looks to be about 7/8" thick. I can't recall if it was rubber or urethane. I used a quality NON interlocking RH mount that actually failed first. That surprised me since I don't recall hearing of a RH failing before a LH mount. I replaced the broken RH one with an OEM spare I had laying around. It ended up causing the drivers side of the engine to sit lower, resulting in header-to-steering box contact.
Anyhow, it may be that your replacement mounts are too thick, causing a misalignment.
https://board.moparts.org/ubbthreads/show...e=6#Post7987159
Re: Big Block Engine Mounts [Re: Kern Dog] #1562442
01/13/14 01:57 AM
01/13/14 01:57 AM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
check the thru bolt that goes through the insulator. Mine was just hitting the block and would not allow it to sit correctly and get all the bolts thru. I struggled for a few hours before removing the mount and seeing a mark on the block. cut the bolt down about 1/4 inch or so and it slipped right in. I almost Lol
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: Big Block Engine Mounts [Re: gregsrt] #1562443
01/13/14 10:44 AM
01/13/14 10:44 AM
NY
NY
The poly mounts are thicker than the ones I took of the motor that could have something to do with it. I had a look to see if anything is touching the block and I don't see anything. It looks like the passenger mount has to come forward. Could the engine mount be installed wrong on the block? I know the poly locs aren't as flexible as the rubber ones. Maybe the problems has always been there but more noticeable now with the poly. Is the k-member adjustable? Could I loosen the bolts and move the passenger side forward ?
Re: Big Block Engine Mounts [Re: Beep Beep] #1562444
01/13/14 05:26 PM
01/13/14 05:26 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
The trans crossmember will let you move it side to a little, depends on how far you have to go, but you could loosen the 4 bolts and the one on the trans rubber mount and try it.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Big Block Engine Mounts [Re: Silver70] #1562445
01/13/14 11:44 PM
01/13/14 11:44 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
If the metal bracket on the engine block was put back on the same way it came off, the problem is with the new mounts themselves.
Re: Big Block Engine Mounts [Re: Kern Dog] #1562446
01/17/14 12:12 AM
01/17/14 12:12 AM
NY
NY
Guys thanks for all the info. If I am running poly engine mounts, what should I use for the tranny mount? Should I run the aftermarket rubber or run the poly tranny mount from Schumacher? Anybody ever use the tranny mount from Schumacher?
Re: Big Block Engine Mounts [Re: Beep Beep] #1562447
01/17/14 05:04 AM
01/17/14 05:04 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
I had the same problem. after 1/2 day I got them installed.
After one weekend at the darg strip they melted at the passenger side.
(some inches away from the headers). Right now I am running only one at the
driver side. Would never buy them again. I think the HD from Mancini are
a better option. Personally I would not use any tranny mounts in PU
unless your chassis is ultra stiff. I would be afriad to brake the trannys neck.
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: Big Block Engine Mounts [Re: Den300] #1562448
01/17/14 10:29 AM
01/17/14 10:29 AM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
I used them on my 67 440, and they work fine.. Only noticable difference is more engine vibration throughout the car vs the stock mounts I replaced em with..
Re: Big Block Engine Mounts [Re: floridian] #1562449
01/23/14 12:33 AM
01/23/14 12:33 AM
NY
NY
I have finally fixed the problem with the passenger side mount. I spoke with Schumacher. They were very helpful with the problem. They recommended moving the hole on the passenger bracket forward. I reamed the hole forward a 1/16 to 1/8 of an inch. Re installed everything and the mount fit perfect and the tranny lined up perfect with the floor hump. Looks like the k-member perch must be slightly out. This explains why my passenger side rubber mount broke before the drivers side.
Re: Big Block Engine Mounts [Re: Beep Beep] #1562450
05/21/14 11:41 PM
05/21/14 11:41 PM
NY
NY
Just wanted to give some feedback after using the Schumacher mounts. The engine doesn't move much like it use to. You do feel very small amount of vibration, but I expected a lot more. The rear view mirror at certain rpm's does vibrate a tiny bit, and looking in the mirror the lines in road do move a bit. All in all I am very happy.
Re: Big Block Engine Mounts [Re: Beep Beep] #1562451
05/22/14 10:27 AM
05/22/14 10:27 AM
Northern NJ, U.S.
71X-mark Offline
71X-mark  Offline
Northern NJ, U.S.
I have 'mitymounts' in my '71GTX and have had no issues. These are positive locking mounts that appears to mimic the dimensions of the stock mounts. They are made by DynaTech Engineering, LLC. You can check them out at www.mitymounts.com.
Re: Big Block Engine Mounts [Re: 71X-mark] #1562452
05/22/14 02:06 PM
05/22/14 02:06 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Thanks for the link! I think I'll get a set.
Re: Big Block Engine Mounts [Re: Beep Beep] #1562453
05/22/14 11:43 PM
05/22/14 11:43 PM
tucson az
frank Offline
frank  Offline
tucson az
I also used the Schumacher mounts for a 496 in my GTX. No issues whatsoever. I'm very happy with mine
Re: Big Block Engine Mounts [Re: 71X-mark] #1562454
05/23/14 06:52 PM
05/23/14 06:52 PM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
I use MityMounts on my 451 stroker, those motor mounts are on regular stress with no failure since years...
