Bent crankshaft causes and myths #1562297
01/12/14 06:28 PM
01/12/14 06:28 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
Has anybody ever seen first-hand a crank bend from laying in a box on a shelf? Now to me it seems physically impossible that something that is built so strong can bend under it's own weight.Now if this were true how could you possibly ship one
I'm building a Chevy small block for my father-in-laws Vette and one his "buddies" tried to tell me not to use the crank he has becuse it's bent because it's been laying on a shelf for too long.
Now if this is true how long does it take for a crank to bend under it's own weight? One week, one hour, a year
Now most of us have purchased a brand new crank and it comes in a box that has probably been on a shelf for a while so are they all bent?
Gus
64 Plymouth Savoy
Dana 60
Re: Bent crankshaft causes and myths [Re: fourgearsavoy] #1562298
01/12/14 07:34 PM
01/12/14 07:34 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Those guys probably believe in unicorns too. If you are concerned about it why not just check it? I would think if you installed only the #1 and #5 upper main bearings in the block, then layed the crank in the bearings, and slowly spun it with a dial indicator on the #3 main journal it would show any signs of a bend. Correct??
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Bent crankshaft causes and myths [Re: fourgearsavoy] #1562299
01/12/14 07:39 PM
01/12/14 07:39 PM
Andrews,In. U.S.of A.
67_Satellite Offline
I'd rather let it lie flat for years than stand it on end and knock it over once.
Re: Bent crankshaft causes and myths [Re: fourgearsavoy] #1562300
01/12/14 07:40 PM
01/12/14 07:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Gus
To me if they bend that easy you dont want it.. but
most crank shops hang them from the back flange BUT
thats to save space in the shop... the one shop I
use to deal with I asked them this myth and thats
all it was.. a myth unless you put a few hundred pounds
on it for a LONG time... its easy enough to check
with V-blocks or on the lathe
Re: Bent crankshaft causes and myths [Re: MR_P_BODY] #1562301
01/12/14 08:26 PM
01/12/14 08:26 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
And batteries will discharge sitting on concrete.
Re: Bent crankshaft causes and myths [Re: drew72] #1562302
01/12/14 08:37 PM
01/12/14 08:37 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
But the old tar top batteries will ( Pre 70's ), not the plastic case ones
Re: Bent crankshaft causes and myths [Re: fourgearsavoy] #1562303
01/12/14 10:24 PM
01/12/14 10:24 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've had several 318 forged steel cranks out of OEM production motors that had the #2 main bent(checking it with a set of V blocks and a dial indicator) .0007 that was just enough to make those cranks kave a tight spot when spinning it without any rods or pistons in the motor. I have heard the same thing on laying cranks down, they will bend Maybe a cast iron crank will I also have several smashed toes from bumping into a crank standing up and it falling forward onto my foot I have several new foregded steel stroker cranks in thier shipping boxes laying on my shelfs in the shop, I have never seen or heard of or had a forged steel crank be bent if it had not spun a rod bearing or suffered some other form of abuse first
Re: Bent crankshaft causes and myths [Re: Cab_Burge] #1562304
01/12/14 10:46 PM
01/12/14 10:46 PM
Indy
moparman89 Offline
moparman89  Offline
Indy
Cant believe this is even a thread. If a crank will bend under its own weigh how would it ever hold up to the stresses of a engine?
School of Automotive Machinists Racing
Re: Bent crankshaft causes and myths [Re: moparman89] #1562305
01/12/14 10:49 PM
01/12/14 10:49 PM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
Chinese cranks are a crapshoot,their idea of runout is when the cat gets away from the butcher block.plus I am quite sure the average employee at the bingdong crankshaft factory cant read.....hence the occasional blem sales from most of the crank distributors.....
SFI 25.5 depends,no leak,even at 213 mph....
Re: Bent crankshaft causes and myths [Re: dakotawilly] #1562306
01/13/14 04:59 AM
01/13/14 04:59 AM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Define bent.
.00000x I'm sure could happen by putting it in a hot sunny window that only heated one side. If it was stored on its side and only supported by the end mains I'm sure there is also measurable deflection but I doubt there are many people with the instruments to accurately measure it.
Kevin
Re: Bent crankshaft causes and myths [Re: dakotawilly] #1562307
01/13/14 05:56 AM
01/13/14 05:56 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Re: Bent crankshaft causes and myths [Re: GTX MATT] #1562308
01/13/14 05:16 PM
01/13/14 05:16 PM
sweden
sshemi Offline
sshemi  Offline
sweden
This is stupid.
If it gets bent when laying down it should get longer when hung and shorter when standing.
Again its just stupid.
Re: Bent crankshaft causes and myths [Re: sshemi] #1562309
01/13/14 07:21 PM
01/13/14 07:21 PM
Sullivan, IN
Mopar Sam Offline
Mopar Sam  Offline
Sullivan, IN
It lays flat in the motor.
Re: Bent crankshaft causes and myths [Re: sshemi] #1562310
01/13/14 07:22 PM
01/13/14 07:22 PM
Guitar Jones Offline
This is stupid.
Man I've been doing it wrong!
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Bent crankshaft causes and myths [Re: Guitar Jones] #1562311
01/13/14 09:17 PM
01/13/14 09:17 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Not a crank but something along the same line are the propeller shaft in navy ships. Some are 200 feet long or more and 36-48 inches in diameter. When docked they turn them very slowly to keep from bending. If they have to work on any part of the shaft they put blocks every so many feet for support, they will bend if not done.If it bends it's remachined where it rides, quite a process since it can't be removed from ship
Re: Bent crankshaft causes and myths [Re: cudaman1969] #1562312
01/13/14 09:28 PM
01/13/14 09:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've never seen one that long but the 1000' ships
here shut down and nothing is turning... I never
turned my shafts even over the winter on my barge
Re: Bent crankshaft causes and myths [Re: MR_P_BODY] #1562313
01/13/14 09:57 PM
01/13/14 09:57 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Shafts must be short, USS North Carolina are that size, and this was first hand knowledge from two engine room guys from a carrier during WW2. They had a lathe that road a cradle with the man riding for the full length.
Re: Bent crankshaft causes and myths [Re: cudaman1969] #1562314
01/13/14 10:11 PM
01/13/14 10:11 PM
dakotawilly Offline
dakotawilly  Offline
I suppose anything could bend under the right conditions,how about the friendly delivery guy tossing it during shipping,you know the old saying,"hey yall watch this"................
Re: Bent crankshaft causes and myths [Re: fourgearsavoy] #1562315
01/13/14 10:12 PM
01/13/14 10:12 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
WITH the major weather TEMP CHANGES in Ohio ...I have heard a CRANKy person can get bent-outa-shape just thinking about the great tropical temps in Florida ....
What say YOU ?
Re: Bent crankshaft causes and myths [Re: dOrk !] #1562316
01/13/14 10:33 PM
01/13/14 10:33 PM
dakotawilly Offline
dakotawilly  Offline
absolutely!!!!!if you don't like the weather in ohio,stick around 5 min it will change.....
