what is this new kind of braided hose? #1562193
01/12/14 04:36 PM
01/12/14 04:36 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
I've been seeing a different kind of braided hose on race cars for the last few years, instead of the braided stainless steel. What is it? Is it lighter or stronger, or cheaper or easier to use? What about safety how does it compare with braided steel in that regard? Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: what is this new kind of braided hose? [Re: Hemi_Joel] #1562194
01/12/14 04:40 PM
01/12/14 04:40 PM
AndyF Offline
AndyF  Offline
Are you talking about the fabric covered lines? I use these when possible. They are easier to work with but they are a little more expensive.
Re: what is this new kind of braided hose? [Re: Hemi_Joel] #1562195
01/12/14 04:49 PM
01/12/14 04:49 PM
fullmetaljacket Offline
Much, much lighter and just as or more stronger. I have it on my car.
Re: what is this new kind of braided hose? [Re: fullmetaljacket] #1562196
01/12/14 05:12 PM
01/12/14 05:12 PM
Minnesota
Minnesota
Yes, what is it called and what is it made of? Thanks
Re: what is this new kind of braided hose? [Re: Hemi_Joel] #1562197
01/12/14 05:14 PM
01/12/14 05:14 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Re: what is this new kind of braided hose? [Re: slantzilla] #1562198
01/12/14 05:19 PM
01/12/14 05:19 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Re: what is this new kind of braided hose? [Re: Hemi_Joel] #1562199
01/12/14 05:45 PM
01/12/14 05:45 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Lighter, but they only give up abrasion resistance and bling. The stainless really never added much strength wise anyway.
Re: what is this new kind of braided hose? [Re: Hemi_Joel] #1562200
01/12/14 05:46 PM
01/12/14 05:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I re-did my whole fuel system the w/Earls lightweight black stuff and it`s awesome looking and no more cut up fingertips.............
Re: what is this new kind of braided hose? [Re: Thumperdart] #1562201
01/12/14 06:53 PM
01/12/14 06:53 PM
Minnesota
Minnesota
Cool! Can you use it for external oil suction lines - pump to pan?
Re: what is this new kind of braided hose? [Re: Hemi_Joel] #1562202
01/12/14 08:42 PM
01/12/14 08:42 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Says it holds 27 hg vacuum...
You can also buy internal springs to keep it from collapsing on tight bends and high vacuum
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: what is this new kind of braided hose? [Re: Hemi_Joel] #1562203
01/12/14 09:03 PM
01/12/14 09:03 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Looks like Andy is using it for that exact application
Gus
64 Plymouth Savoy
Dana 60
Re: what is this new kind of braided hose? [Re: fourgearsavoy] #1562204
01/12/14 11:23 PM
01/12/14 11:23 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Alot of the nylon braid line is only good to 350 degrees. I've used it, but this go around im doing stainless braid with black fittings.
Mopar to the bone!!!
Re: what is this new kind of braided hose? [Re: 72Swinger] #1562205
01/13/14 09:09 AM
01/13/14 09:09 AM
408Dust Offline
408Dust  Offline
Don't use it, does not last as long as stainless braided. Your experience my differ from mine but for the added cost it's not worth it.
Re: what is this new kind of braided hose? [Re: 408Dust] #1562206
01/13/14 02:00 PM
01/13/14 02:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What doesn`t last?
Re: what is this new kind of braided hose? [Re: 408Dust] #1562207
01/13/14 03:32 PM
01/13/14 03:32 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
Have been using different brands on different applications for years and have yet to have any problems with any of them except for once and that was our fault. If you ever use the Jegs stuff and take a fitting off you MUST cut the hose a little shorter or the hose will not seat back on the fitting. We blew a trans line off. Fixed it and never had a problem again. And that was on one of Jeg's top dragsters.
Back in the swing of things at Painless again! Great to be back!
Re: what is this new kind of braided hose? [Re: BJS racing] #1562208
01/13/14 10:29 PM
01/13/14 10:29 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I will never use anything but the Aeroquip socketless hose again
http://www.summitracing.com/search/brand...se?autoview=SKU
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: what is this new kind of braided hose? [Re: Thumperdart] #1562209
01/14/14 10:16 AM
01/14/14 10:16 AM
408Dust Offline
408Dust  Offline
Pro-Flo 350 Series Nylon Braided Hose,use what you want but from my experience it does not like C12 very well.
What doesn`t last?
Re: what is this new kind of braided hose? [Re: 408Dust] #1562210
01/14/14 10:40 AM
01/14/14 10:40 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
What doesn`t last?
Most braided hose has rubber inside, no rubber will last very long. It's no different than regular rubber hose without the braid, it don't last forever.
A lot guys think it last for years but it don't.
It should only be used in short lengths and replaced every couple three or so years.
Re: what is this new kind of braided hose? [Re: Challenger 1] #1562211
01/14/14 11:28 AM
01/14/14 11:28 AM
GEORGIA
barracuda7199 Offline
GEORGIA
Re: what is this new kind of braided hose? [Re: Challenger 1] #1562212
01/14/14 11:46 PM
01/14/14 11:46 PM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
Buy hoses made for use with alcohol. They should last a little longer.
Again over time FUEL of any kind is going to eat them up. Just a matter of how soon.
