what is this new kind of braided hose?
#1562193
01/12/14 04:36 PM
01/12/14 04:36 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
I've been seeing a different kind of braided hose on race cars for the last few years, instead of the braided stainless steel. What is it? Is it lighter or stronger, or cheaper or easier to use? What about safety how does it compare with braided steel in that regard? Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: what is this new kind of braided hose?
[Re: Hemi_Joel]
#1562199
01/12/14 05:45 PM
01/12/14 05:45 PM
Posts: 22,727 Bitopia
jcc
Bitopia
Lighter, but they only give up abrasion resistance and bling. The stainless really never added much strength wise anyway.
[Re: fourgearsavoy]
#1562204
01/12/14 11:23 PM
01/12/14 11:23 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Alot of the nylon braid line is only good to 350 degrees. I've used it, but this go around im doing stainless braid with black fittings.
Mopar to the bone!!!
[Re: 408Dust]
#1562210
01/14/14 10:40 AM
01/14/14 10:40 AM
Challenger 1
Cincinnati, Ohio
Pro-Flo 350 Series Nylon Braided Hose,use what you want but from my experience it does not like C12 very well.
Don't use it, does not last as long as stainless braided. Your experience my differ from mine but for the added cost it's not worth it.
What doesn`t last?
Most braided hose has rubber inside, no rubber will last very long. It's no different than regular rubber hose without the braid, it don't last forever.
A lot guys think it last for years but it don't.
It should only be used in short lengths and replaced every couple three or so years.
