Ez efi - atomic etc for 500ci
#1562040
01/11/14 09:56 PM
01/11/14 09:56 PM
Posts: 738 Oh Canada
EV2CUDA
Oh Canada
I would like to try one of the self learning efi systems. I think my combo is on the edge for them. Will one support what I have? 500 cube, 11-1, 240 duration solid roller with max wedge stage 6 heads. It should make 575hp. It's a street car. It runs a msd digital 6al. Don't know if that matters. I don't have the engine running yet, but its in its home. I have an hp1000 Holley but my poor choice as it has no vac ports.
71 Barracuda 383 4spd (500ci) 69 camaro 598, NOS 69 barracuda bbc procharger 77 t/a 6.0 turbo project 78 t/a 400 77 corvette 1983 hurst/olds 03 Viper 79 360 macho 71 demon 360 78 Warlock 5.7 hemi project
Re: Ez efi - atomic etc for 500ci
[Re: Dragula]
#1562042
01/12/14 12:02 AM
01/12/14 12:02 AM
EV2CUDA
Oh Canada
My mistake, cam is 262@50 duration. Comp 308r. .575 lift.
[Re: EV2CUDA]
#1562045
01/12/14 01:15 PM
01/12/14 01:15 PM
Posts: 12,397 Taxes & Virus's R-US, NY
Dragula
My mistake, cam is [Email]262@50[/Email] duration. Comp 308r. .575 lift.
That is a little tougher...I had trouble with a cam at 244 duration and to go to a custom curve on the distributer to get idle vacuum higher...Basically more timing at idle. This can also have the draw back of being tough to start if you go too far.
At 262 duration, I would be looking at the Sportsman XFI self learning system...you can still use a tbi, but it won't give you the headaches of trying to get the idle and transition to work.
[Re: Dragula]
#1562049
01/13/14 05:16 AM
01/13/14 05:16 AM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
My 493 has the MP509 which is 248 @ .050. I'm running a Commander Pro TBI which is pretty stone age now and the only way we could make it behave at idle/low RPM was to set it to run alpha numeric under 1800 rpm. The Holley system will allow you to switch automatically. With a big cam there is so much reversion that it just drove the closed loop nuts. Once we went A/N it ran like nails. Starts instantly and idles well even tho the A/F indicates pig rich. If we lean the idle out it runs like crap so we just set the idle where it sounds happy and ignore the A/F.
Kevin
