2005 cummins injector change out #1561597
01/10/14 07:43 PM
01/10/14 07:43 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
How hard are the injectors to change out in a 05 Ram? Mine are starting to get weak and I can't take a chance on them any longer. I found some online for 200 each. A place out of FL called Diesel logic.
Re: 2005 cummins injector change out [Re: fastmark] #1561598
01/10/14 08:22 PM
01/10/14 08:22 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
Re: 2005 cummins injector change out [Re: Golden-Arm] #1561599
01/10/14 09:56 PM
01/10/14 09:56 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Thanks. I still like to have a service manual to refer to torque specs, valve lash and such. I bet 5 and 6 are tough, though.
Re: 2005 cummins injector change out [Re: fastmark] #1561600
01/11/14 01:43 PM
01/11/14 01:43 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
The youtube video was showing a 06 or 07 truck. Your valve cover is a little different on your 05. Yours will have a lower valve cover plate to remove to get the wirirng out of the way and will give you better access to prying the injectors out. Also dont worry about not having the supply tube removal tool. They come out pretty easily with a little wiggling and tugging. I use a small set of angled needle nose pliers too grab them behind the threads and pry them out. Be very careful tightening the electrical connections to the injector. It is very easy to twist the stud off of the top of the injector.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 2005 cummins injector change out [Re: 71yelladustr] #1561601
01/11/14 11:48 PM
01/11/14 11:48 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I think I can do it pretty easy. The hard part is deciding which injectors to buy. Rebuilt Bosch or new! Where is the best place to buy them?
Re: 2005 cummins injector change out [Re: fastmark] #1561602
01/12/14 12:53 PM
01/12/14 12:53 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I installed a set of "cheap" injectors provided by a customer one time.... and it pumped fuel into the crank case. Make sure you keep an eye on the oil level after performing this.
....we ordered new O rings from Cummins and all was well....except for the additional labor of doing it twice. You could see four of them slowly pooling fuel up around the base of the injector while it was running. The new O rings were obviously a larger diameter than what came on the supplied parts.
