Best way to remove rust and paint #156116
11/24/08 07:54 PM
11/24/08 07:54 PM
Shopping @ HoBo Fright
340SIX Offline OP
Doc Flappergas's Evil Twin
340SIX  Offline OP
If sand blasting is not an option?
Are those 3-M wheels anygood?
If so do they make them for a 4" or 4.5" grinder as I realy don't want tp use a drill. Any other option?
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Best way to remove rust and paint [Re: 340SIX] #156117
11/24/08 07:56 PM
11/24/08 07:56 PM
LAKE TEXOMA
oldman Offline
oldman  Offline
LAKE TEXOMA
DYNAMITE
you never walked in that mans shoes or seen things through his eyes and stood and watched with helpless hands while the heart inside you dies, but for the grace of god it could be you instead of him.
Re: Best way to remove rust and paint [Re: 340SIX] #156118
11/24/08 08:12 PM
11/24/08 08:12 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
I've been using the 3M wheels (cookies) and fiber wheels (kind of like wire wheels but made of abrasive). And of coarse 80 grit sand paper on the big areas.
Re: Best way to remove rust and paint [Re: oldman] #156119
11/24/08 08:13 PM
11/24/08 08:13 PM
STEELER NATION!!!
Skeez Offline
Pretty in Pink
Skeez  Offline
Pretty in Pink
STEELER NATION!!!
Re: Best way to remove rust and paint [Re: bigblock340power] #156120
11/24/08 08:14 PM
11/24/08 08:14 PM
340SIX Offline OP
340SIX  Offline OP
I looked at ebay and googled 3-m wheels and all i saw were for drills is that what you are useing?
Re: Best way to remove rust and paint [Re: 340SIX] #156121
11/24/08 08:35 PM
11/24/08 08:35 PM
NY NY
3
340duster340 Offline
NY NY
where is the rust located?
pretty sure there are sand paper flap wheels for grinder.
i have used the 3m pads for die grinder which also work well.
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: Best way to remove rust and paint [Re: Skeez] #156122
11/25/08 01:31 AM
11/25/08 01:31 AM
Skeez- Can you please post a bigger pic of your avatar? Can't quite make out what it says.. Looks intersting.
Re: Best way to remove rust and paint #156123
11/25/08 03:22 AM
11/25/08 03:22 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Wire wheel on a drill works well too.
Re: Best way to remove rust and paint [Re: DaytonaTurbo] #156124
11/25/08 06:03 AM
11/25/08 06:03 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I burnt up a drill using wire wheels to clean up rust on my floor.
i've used the sandpaper flapper wheels on a grinder before too, and they didn't last very long, I wouldn't reccommend them. the stiff sponge wheels work well too, but again, the oens I had were for use in a drill. all the dust I created got into the drill and it didn't live very long
**Photobucket sucks**
Re: Best way to remove rust and paint [Re: 340SIX] #156125
11/25/08 09:29 AM
11/25/08 09:29 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
I DA them with 80 grit But I'm not a professional painter and can't spell so what do I know, LOL
Re: Best way to remove rust and paint [Re: 340SIX] #156126
11/25/08 09:39 AM
11/25/08 09:39 AM
WI
RestoRick Offline
RestoRick  Offline
WI
Depends where the paint is and how deeply penetrated the rust is; also how large of an area... more details please.
Rick
Re: Best way to remove rust and paint [Re: RestoRick] #156127
11/25/08 09:41 AM
11/25/08 09:41 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
3M bristle discs on a angle die grinder.
http://solutions.3m.com/wps/portal/3M/en...9beH55CPWS904gl
the little fingers on the disc help keep from building up to much heat.
perception is 90% of reality
Re: Best way to remove rust and paint [Re: 340SIX] #156128
11/25/08 09:45 AM
11/25/08 09:45 AM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
The best way is to dip it.
Why is blasting out of the question?
NMCA NSS 67 Coronet
Re: Best way to remove rust and paint [Re: Barry70GTX] #156129
11/25/08 12:06 PM
11/25/08 12:06 PM
Anywhere the British Secret Se...
Moonraker Offline
Moonraker  Offline
3M also makes an 8" soft pad you can put on a grinder with 40/80/120 grit self adhesives sanding disks. Takes paint and surface rust right off no problems. Way faster than a DA sander and way cleaner more workable surface than wire wheels and things like that. Stripped several cars down to metal and will never use paint stripper again except in door jambs and heavily contoured areas. As with any type of grinding though make sure to work different areas as to not build up to much heat as you can warp the panels. Dipping works great also as stated above but it is expensive as hell, last quote I got was $5000 for a whole car.
Re: Best way to remove rust and paint [Re: Barry70GTX] #156130
11/25/08 01:41 PM
11/25/08 01:41 PM
340SIX Offline OP
340SIX  Offline OP
Long story:
The car was dipped but the doner part I am using was not. Orginaly I should have not had to use the parts that need cleaned up! But the body shop the car used to be at cut the whole front floor out instead of useing the 3/4 patch pans I gave them.They also ruined the quaters by cutting them off to make the trunk floor easy to install
Went out of biz and gave me that car back {they screwed me out of 5800 bucks and lost lots of parts.Car has sat a long time but now I am going to have time and $$ to at least gather the parts I neeed and do some work.
As far blasting goes I paid 2K for new grass sod and wife looked at me like
BUT as of This morn she gave the go ahead to blast what Ineed to
After Rredi Strip
Re: Best way to remove rust and paint [Re: 340SIX] #156131
11/25/08 01:49 PM
11/25/08 01:49 PM
Goodyear Arizona
midnite360 Offline
midnite360  Offline
Goodyear Arizona
Drive really really fast!
Re: Best way to remove rust and paint [Re: midnite360] #156132
11/25/08 01:54 PM
11/25/08 01:54 PM
340SIX Offline OP
340SIX  Offline OP
After body shop
Re: Best way to remove rust and paint [Re: midnite360] #156133
11/25/08 01:59 PM
11/25/08 01:59 PM
340SIX Offline OP
340SIX  Offline OP
Re: Best way to remove rust and paint [Re: 340SIX] #156134
11/25/08 02:38 PM
11/25/08 02:38 PM
Moonraker Offline
Moonraker  Offline
He means drive it so fast the paint and rust come off.
Re: Best way to remove rust and paint [Re: Moonraker] #156135
11/25/08 02:44 PM
11/25/08 02:44 PM
Goodyear Arizona
midnite360 Offline
midnite360  Offline
Goodyear Arizona
LOL
