Re: Callin on Engine experts
[Re: Hem1orange]
#1561050
01/09/14 02:03 AM
01/09/14 02:03 AM
Posts: 43,244 Bend,OR USA
Cab_Burge
I'm no engine expert but I have built, raced and dyno tested a bunch of BB Mopars for all kinds of applications, race, street and strip and street only. I would look at using one of the Comp Cams grinds, Magnum 270 H, 280 H or maybe one of the Xtreme energy grinds like the XE262H or the bigger XE268 H grinds. I have never seen a stock unblueprinted BB Mopar be anywhere close to blueprint specs . from the factory on any part of the motors My message is that Imperial motor problly doesn't have a true 9.0 to 1 compression ratio now with the new heads, you can do some measuring on the deck hieghts to see what it ends up with as far as the current parts, if it is above 8.5 to 1 comp ratio then think about what you want to do, if it is below 8.4 to 1 I would probally try getting it closer to 10.0 to 1 with the new aluminum heads and use a bigger cam than the ones I recommended, maybe the Comp XE275HL or XE285HL grinds IHTHs
[Re: Hem1orange]
#1561053
01/09/14 06:24 AM
01/09/14 06:24 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
What size engine? 440, 383? What vehicle is it going into, what weight and tire size? With the aluminum head and intake, and being in Colorado you can push the compression up a bit.
If it is a 440, I can make you a deal on a near new RPM intake, 780 Holley street avenger carb, and Accell street billit all-in-one distrubitor, and a few other parts off my 440 that I am converting to EFI.
[Re: Hem1orange]
#1561056
01/09/14 12:12 PM
01/09/14 12:12 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
That cam would be a bit big for a bone stock low stall converter, IMHO. If you can find a high stall converter meant for a 340 or Hemi, then fine. Get the cranking compression(or dynamic compression) back up to the high end for the heads and fuel and cam you will run, or go with a cam that only has four or five more degrees duration than stock. what you want is to not lose low speed working compression due to the intake valve closing a lot later with a moderately big cam like the Edelbrock you are looking at. If you use that cam with a stock 2200 rpm converter, it will be in the bottom half of the gear a LONG time, making the car slow out of the gate by a bunch. If you want to use the low stall converter, take a look at the ones CAB recommended, the 268H or 270 H for total duration Vs the stock cam. There is a web site called BIGBOYZ (its a Harley motorcycle head porters page) that has a dynamic compression calculator under one of the listings, to help you figure this all out. Getting that compression up there will be worth about 30 ft lbs of torque on the bottom end, by the way. Getting it right will pay dividends if fuel mileage as well.
[Re: WO23Coronet]
#1561063
01/09/14 06:53 PM
01/09/14 06:53 PM
Posts: 2,091 Delray beach, Florida
Performance Only
for what you're doing, something in the range of 218-224@ .05 will work. look up a comp xe262h or the xe268h. they'll help with the low cylinder pressure and have good throttle response and low end torque.
machine shop owner and engine builder
