Re: distributor/oil pump bushing in block
[Re: barracudabob]
#1561004
01/09/14 12:16 AM
01/09/14 12:16 AM
They are listed from any Mopar Performance dealer but I really like the ones sold by Pioneer--they do not wear like the Mopar units--seems like for the last few years any engine we tear down that had the Mopar supplied unit has scooring on shaft and wear--we always size them after install so they were not too tight but the Pioneer made ones don't seem to do that and they usually do not need any resizing/honing etc best to use and old oil pump shaft to install it with--you can grind the teeth off and use it even if a cam is in the block--a little notch ground into the shaft with a cut off wheel will "ream" it out to size usually if it is tight
[Re: barracudabob]
#1561010
01/09/14 04:49 PM
01/09/14 04:49 PM
Posts: 25,903 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The Pioneer number is PC-780
