F-440-HP Engine Block Date Code Info Required #1560788
01/08/14 12:49 PM
01/08/14 12:49 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Is the F-440-HP only available for a 1969 date coded engine block?
Re: 440 HP Engine Block Date Code Info Required [Re: vinnyd76] #1560789
01/08/14 12:55 PM
01/08/14 12:55 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
No.....F440 HP blocks were made for about 1 calendar year. Cast dates started approx. around May 1969 and went to May 1970. Engine assy dates started approx. July 69 and went to July 70. Of course there are always exceptions....please take the info above as a general guide. Best way to confirm if you have an actual "F" 70 engine is to look at the VIN# just above the oil pan rail and all of the info stamped into the top pad. Casting dates can sometimes be misleading.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
