Re: What tool do you use for cylinder head porting?
[Re: IcorkSOAK]
#1560225
01/07/14 02:22 AM
01/07/14 02:22 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
... a Craftsman die grinder. Had it for 20 + years.
Well I know who not to get heads from. Thanks for the tip.
[Re: barracuda7199]
#1560226
01/07/14 02:24 AM
01/07/14 02:24 AM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I use a Foredom 44T hand piece and motor. I buy my pieces separately off ebay as you get better pricing that way and can get the heavy duty parts. The 44T hand piece is the one to go with as its for 1/4 inch shank. I always keep extra parts on hand just in case a cable or something needs changed. Here is a link just to show you the needed pieces but its priced way to high. http://www.ebay.com/itm/FOREDOM-K-5240-W...=item1e67229771If you are only going to do a couple of jobs buy a electric or air grinder from Harbor Freight. If you go with electric buy a router speed control so you can SLOW it down some. Air can be slowed with an air regulator.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: barracuda7199]
#1560231
01/07/14 02:36 AM
01/07/14 02:36 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I use a Dewalt grinder(I believe its Dewalt.. its the yellow one) with a controller... I also have the air grinders... I usually have certain bits in each unit so I dont spend time changing
[Re: barracuda7199]
#1560233
01/07/14 03:00 AM
01/07/14 03:00 AM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
He says he's looking for a flexible shaft which the foredom have but they are not the cheapest way to go. I love mine and its all I've used for the last five years. My other air and electric ones sit in the cupboard.
[Re: pittsburghracer]
#1560234
01/07/14 11:43 AM
01/07/14 11:43 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Dolla, dolla, dollar bills, y-all!!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
#1560236
01/07/14 12:29 PM
01/07/14 12:29 PM
Posts: 30,632 Florida STAYcation
IcorkSOAK
Financed his waterbed
Florida STAYcation
If he is only going to play around some or only do a couple sets of heads its CRAZY to spend a lot of money. Head porting is not for everyone and as most know its real easy to screw up a set of heads.
BUTTT BURGHERguy ... no need to spend a ton of $$$ on one. You can clean-up blocks, exh mans etc ...
#1560241
01/07/14 01:52 PM
01/07/14 01:52 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
i use a tool called a Dwayne Porter.(no, im not callin Dwayne a TOOL)
