79 W200 Cab heater fan does not work #1559987
01/06/14 06:21 PM
01/06/14 06:21 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
Anyone have the schematic for this or possibly blower motor is broke. It never worked since I had it for short time. Any other things to check?
Guns, God, and Country. U.S. Veteran
Re: 79 W200 Cab heater fan does not work [Re: Wizard] #1559988
01/06/14 06:25 PM
01/06/14 06:25 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
My 78 W200 did the same thing.....until I wiggled the blower motor fuse. Came right on....
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: 79 W200 Cab heater fan does not work [Re: ChrgrCuda] #1559989
01/06/14 07:56 PM
01/06/14 07:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Run a jumper wire from the battery to the fan and see if it runs. If it runs then check the blower motor resister on the heater housing for power in and out.
Re: 79 W200 Cab heater fan does not work [Re: ChrgrCuda] #1559990
01/06/14 08:51 PM
01/06/14 08:51 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
Are you talking about the fuse in the glove box on top of dash or is there another fuse down on the blower motor under the dash?
Re: 79 W200 Cab heater fan does not work [Re: Wizard] #1559991
01/06/14 08:56 PM
01/06/14 08:56 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
There a resister in the top of the heater box that burns out too
If you find it burnt change your blower motor
Re: 79 W200 Cab heater fan does not work [Re: BulletBob] #1559992
01/06/14 10:43 PM
01/06/14 10:43 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Fuse in the glove box.
