Firewall Hole for 1973 Charger Cruise Control Harness #1559899
01/06/14 03:51 PM
01/06/14 03:51 PM
Georgia
skh Offline OP
skh  Offline OP
Georgia
Where,exactly, is the hole located for the cruise control wiring harness in a 1973 B Body? I have to drill this in the right place, the first time! Thanks.
Re: Firewall Hole for 1973 Charger Cruise Control Harness [Re: skh] #1559900
01/06/14 05:35 PM
01/06/14 05:35 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Would suggest checking the Factory Service Manual . . . usually they show a location in there . . .
Cheers
Mark
Re: Firewall Hole for 1973 Charger Cruise Control Harness [Re: skh] #1559901
01/06/14 08:09 PM
01/06/14 08:09 PM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
Here's a 74 B body fire wall. It may be one of the holes on the driver's side by the inner fender.
Re: Firewall Hole for 1973 Charger Cruise Control Harness [Re: 74RALLYE] #1559902
01/06/14 09:03 PM
01/06/14 09:03 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
I am not sure on this one, but I doubt you would need to drill in order to pull this through an existing hole. How big of a connector are we talking here?
It would make sense to use a hole near the steering column. This would either be the oval hole that is used for the clutch cable (MT) or plugged (AT) OR the round hole just below and to the right of the brake booster where the speedo cable passes through.
The factory probably had it pinned to the fuse block/bulkhead connector originally so no extra hole but I could be wrong.
Re: Firewall Hole for 1973 Charger Cruise Control Harness [Re: 74RALLYE] #1559903
01/06/14 09:41 PM
01/06/14 09:41 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
All mopars have a hole for the cc harness
There is a grommet as part of the harness.
The hole is the one across from the m-c hole on the right side
Re: Firewall Hole for 1973 Charger Cruise Control Harness [Re: ThermoQuad] #1559904
01/06/14 09:50 PM
01/06/14 09:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The instructions for factory cruise-control kit instruct you to drill a hole using a stamped dimple as the locator.
