Page 1 of 3 1 2 3
Torque converters #1559831
01/06/14 02:51 PM
01/06/14 02:51 PM
Gilbert AZ
tsanchez Offline OP
tsanchez  Offline OP
Gilbert AZ
Looking at maybe changing converters, current one was built by a friend 25yrs ago. Its a 8 inch and he refreshed it this spring but I feel its holding car back, it should be mph in the 130s and so far has only gone 126. Feels like its on a dyno all the time, never pulls rpm strong.
Who makes a good 727 converter in the 55-6500 stall range. This is for my AMC but there is really no difference in converter but the ring for starter.
Re: Torque converters [Re: tsanchez] #1559832
01/06/14 02:59 PM
01/06/14 02:59 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
What ET does it run?
Could be slipping.
Re: Torque converters [Re: tsanchez] #1559833
01/06/14 03:28 PM
01/06/14 03:28 PM
Saskatchewan (SK)
79410aspenrt Offline
Saskatchewan (SK)
i would call Lenny at Ultimate Convertor. I got one from Lenny last year.
I gained 2 mph, 3 tenths, and my 60' jumped to 1.55 from 1.70.
I changed nothing else but convertor.
Re: Torque converters [Re: 79410aspenrt] #1559834
01/06/14 03:32 PM
01/06/14 03:32 PM
Gilbert AZ
tsanchez Offline OP
tsanchez  Offline OP
Gilbert AZ
It ran 10.53 at 126 in bowling green this fall at drag week. 1.51 60, car weighs 3500lbs, 4.44 gear and 28 inch tires.
Re: Torque converters [Re: tsanchez] #1559835
01/06/14 03:36 PM
01/06/14 03:36 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
that mph seems about right for the ET. my car is only 60ing in the 1.5 range but I blame it on the 3.55 gears. I have the same converter that was behind the big block. its a 9" from Lenny at Ultimate
Re: Torque converters [Re: sixpackgut] #1559836
01/06/14 03:40 PM
01/06/14 03:40 PM
Gilbert AZ
tsanchez Offline OP
tsanchez  Offline OP
Gilbert AZ
Not so worried about the 60 foot but that it wont rpm right, always seems like its loaded, never two strokes or gets on the cam. Also mph is low, the 1/8 mile times and mph are better than at 1/4. This engine should be pushing it to 133 or so.
Re: Torque converters [Re: tsanchez] #1559837
01/06/14 03:42 PM
01/06/14 03:42 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
starving for fuel maybe. your jet change didn't do anything. maybe its not the converter
Re: Torque converters [Re: sixpackgut] #1559838
01/06/14 03:47 PM
01/06/14 03:47 PM
Gilbert AZ
tsanchez Offline OP
tsanchez  Offline OP
Gilbert AZ
Plenty of fuel, I thought that last year and redid the fuel system, no change, wide band had it at 9-1 afr leaned it out and am close now.
Re: Torque converters [Re: tsanchez] #1559839
01/06/14 04:03 PM
01/06/14 04:03 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Lenny a UCC here also...great service and product
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Torque converters [Re: Eric] #1559840
01/06/14 04:14 PM
01/06/14 04:14 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Cut and pasted from Moparts fastest section. Seems like you are right where you should be mph wise. I'm down some running 10.06@130mph but 4.88 gears, a small carb, and a 550 lift cam will kinda peter out.
10.27 @ 129.9b 68 fb cuda 2980 lbs, 9.0x30 tire,leaf springs. 500”, 4150 carb, indy ez-1s Footin it cudasteve68
10.31 @ 131.85, 1.36 60', Kevins440, 493RB, Indy 440-1's, stock '63 cross ram, 3300lb.
10.32 @129.01 1.45 60' DaveS 73 Swinger 446 E-heads, Mega-Squirt EFI SS springs Staightline Perf. Cam
10.325@ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430#
10.33 @ 130.00, 1.52 60' Bubba, '80 Mirada, 440, 3630#
10.38 @ 128 mph, 1.44 60', 68 Valiant 100, 408, Indy 360-2s, pump gas, 3100 lbs, 340_Dart
10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5"
10.43 @127.23 wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs
10.43 @ 126.41 1.42 60’,70 Superbee 451,3500 lbs,SS sprgs,Std port EZ's, super451b
10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor.
10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#.
10.50 @ 126.68 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor
10.500 @ 131.05,03 Dakota R/T Turbocharged 408, rtspeedemon
10.50 @ 128.00,1979 Chrysler 300,Bown 408 SB,727,4:56 gears Crizila
10.50 @ 127.00, daron 73 duster, sb street car
10.52 @ 130, 400 stk bot end E heads,w squeeze, pump gas,BB70DUSTER
10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude
10.57 @ 126, 1.45 60’3650#, 66 Coronet440,9in slks.cal tracs,no pwr aders, theman440.
10.58 @ 125,1.44 60’,70 dart,493,pump gas,eddy rpm's,solid cam,493 Dart
10.59 @ 127, 1.49 60' 70 Bee 440 eddy rpm heads
10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads
10.6167 @ 133.65, 4190#.030 over 360, Sgl Turbo, 99 Dakota, Duner
10.62 @ 125mph,69 Cuda, 394"SB IMM ported Eddies,IMM flat tappet, Pump gas, 275 Radials, imin269
10.64 @ 124.50, 1.49 60', RVA, 440ci 3165#
10.65 @ 123.43 1.45 60ft,11secdart 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers,
10.66 @ 126 Mr. Belvedere, 66 Belvedere 470, 3725#
10.66 @ 124.84, 1.51 60'3800lb 67 GTX, 512ci.,s/s springs, dana 60, 4.10 gears, jkgtx
10.67 @ 128.3, 1.55, 72 Chally, Auto/Pump Gas Street Car, 3850, full exh, DOT's *WeDgiE*
10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust
10.68 @ 125, 10secGTX 67 GTX 3670#
10.68 @ 125, 73 Str/Strip Dart stock 440/727 pump gas ET Streets Mopar65
10.68 @ 123 mph. 76' Volare 406" iron head magnum motor, 904 trans, 3300 lbs on 9" Radials. Hyd roller camshaft -- StandOnIt
10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs.
10.71 @ 126.12, gj69charger, '69 charger, 500cid
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Torque converters [Re: tsanchez] #1559841
01/06/14 04:36 PM
01/06/14 04:36 PM
Aurora, Oh.
max_maniac Online happy
max_maniac  Online Happy
Aurora, Oh.
If you think it should MPH at 133 then you should also think you should ET at 10.0 or better.
Russ
Re: Torque converters [Re: max_maniac] #1559842
01/06/14 04:47 PM
01/06/14 04:47 PM
Gilbert AZ
tsanchez Offline OP
tsanchez  Offline OP
Gilbert AZ
Russ
Exactly, I can find the et once the mph is there, engine should be capable, its 12.4-1 heads flow in the 360 range and cubic inches at 436, tunnel ram with two dominators, cam is .794/.746 278/286 at .050 on a 110 center. even if the combo is wrong and doesnt 60 or et right when it comes on it should mph out the back and its just not. Old iron headed 401 with a flat tappet was running 11.2 at 122 with same converter, had been in car for 25 yrs and then et dropped to 11.7 and 118 so I thought engine was tired so it came out and new one built. it still has same issue so I think that is where its at as drastic tuning changes really make not much difference.
Re: Torque converters [Re: max_maniac] #1559843
01/06/14 04:50 PM
01/06/14 04:50 PM
okla.
sam64 Offline
sam64  Offline
okla.
I went from 29.5 to 28 w 4,30 gears and my car didn't like that one bit.what kind of rpms you turning at the stripe w those 28 tall tires?
Re: Torque converters [Re: tsanchez] #1559844
01/06/14 05:48 PM
01/06/14 05:48 PM
Saskatchewan (SK)
Saskatchewan (SK)
you should be running 10.0-10.10's with your combo.
I ran 10.85 @ 126 mph off the trailer, no tuning.
436'' w2 heads, 13.1, tunnel ram with 650's, 660/632 lift and 277/288@.050. 4.30 gear, 28'' tire. 3800 lbs
first thing I would change is convertor. i picked up with my swap in convertors. my car felt sluggish and i knew it had a lot more in it.
Re: Torque converters [Re: 79410aspenrt] #1559845
01/06/14 06:37 PM
01/06/14 06:37 PM
Gilbert AZ
tsanchez Offline OP
tsanchez  Offline OP
Gilbert AZ
Turns right at 6900-7000 at the stripe.
Re: Torque converters [Re: tsanchez] #1559846
01/06/14 06:44 PM
01/06/14 06:44 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Did you get my pm? With that cam and head combo you should be solidly in the 9`s unless it`s a heavy pig AND that`s w/a Continental vert.........
Guess this is an example how "easy" n/a tuning is.........
Re: Torque converters [Re: Thumperdart] #1559847
01/06/14 06:52 PM
01/06/14 06:52 PM
Gilbert AZ
tsanchez Offline OP
tsanchez  Offline OP
Gilbert AZ
Yes I got your pm, thanks! and yes it kinda is a heavy pig (3500) but it should still pull on the big end. Hell last yr I took out 200 lbs and didnt really make a difference.
Re: Torque converters [Re: tsanchez] #1559848
01/06/14 06:57 PM
01/06/14 06:57 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Little tougher at that weight but low 10`s as stated seem doable w/ EVERYTHING being right...........
Re: Torque converters [Re: Thumperdart] #1559849
01/06/14 07:37 PM
01/06/14 07:37 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
What is your 1/8 mile et and mph ? Ron
Re: Torque converters [Re: tsanchez] #1559850
01/06/14 07:54 PM
01/06/14 07:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Being it was HOT down there thats what the HP shows
for that day... the ET and MPH is right in line so
thats what it had for power that day.... what was the
A/F ratio that day
Page 1 of 3 1 2 3
