Re: 428 R3 Block Build
[Re: tubtar]
#1559678
01/06/14 07:32 PM
01/06/14 07:32 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Cometic gasket mls head gasket. It's the same as a stock sb mopar engine now. You have never seen a sb mopar with compression?
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1559679
01/06/14 08:59 PM
01/06/14 08:59 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
10 1/2" head studs will hold just fine.
With 7/16"in the original 10 the extra 8 3/8 bolts are necessary.
It appears a lot of clean up machining could be done on this block.
[Re: fullmetaljacket]
#1559681
01/07/14 09:38 AM
01/07/14 09:38 AM
Posts: 1,770 Pa
Wv68charger
Pa
Pete. You and Chuck are mad scientists while in the closet of being artist.
Missed you guys in Detroit, was in and out. Happy Holidays.
Yea and there Lab is something else ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Jacob Pitt]
#1559683
01/07/14 01:30 PM
01/07/14 01:30 PM
Posts: 189 long island new york
kingdust
I have an early R1 with diamond heads at 15.3 with a 1008 and don't have any problems. ![](/ubbthreads/images/graemlins/Twocents.gif) nice work by the way.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
