Page 1 of 3 1 2 3
428 R3 Block Build #1559664
01/06/14 01:56 AM
01/06/14 01:56 AM
SouthEast Michigan
P
PETE@BESTMACHINE Offline OP
P
SouthEast Michigan
We have a cool small block build going on, R block, 4.125 Bore, 4"crank, Indy 360 Heads CNC ported, solid roller, 14 to 1 compression etc. Had to clearance block for the new comp lifter with the inside tie bars and we bushed it due to the lifter uncovering the oil galley at lift. Before picture
Re: 428 R3 Block Build [Re: PETE@BESTMACHINE] #1559665
01/06/14 01:57 AM
01/06/14 01:57 AM
SouthEast Michigan
P
P
SouthEast Michigan
After picture
Re: 428 R3 Block Build [Re: PETE@BESTMACHINE] #1559666
01/06/14 01:58 AM
01/06/14 01:58 AM
SouthEast Michigan
P
P
SouthEast Michigan
Lifter bushings
Re: 428 R3 Block Build [Re: PETE@BESTMACHINE] #1559667
01/06/14 01:59 AM
01/06/14 01:59 AM
SouthEast Michigan
P
P
SouthEast Michigan
More
Re: 428 R3 Block Build [Re: PETE@BESTMACHINE] #1559668
01/06/14 02:00 AM
01/06/14 02:00 AM
SouthEast Michigan
P
P
SouthEast Michigan
Extra Head bolt Holes
Re: 428 R3 Block Build [Re: PETE@BESTMACHINE] #1559669
01/06/14 02:05 AM
01/06/14 02:05 AM
SouthEast Michigan
P
P
SouthEast Michigan
Last one for now
Re: 428 R3 Block Build [Re: PETE@BESTMACHINE] #1559670
01/06/14 02:13 AM
01/06/14 02:13 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Looks nice! What is your target hp on this motor?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 428 R3 Block Build [Re: 1967dartgt] #1559671
01/06/14 02:16 AM
01/06/14 02:16 AM
warren, mich.
dwayne welder Offline
warren, mich.
HAPPY NEW YEAR Pete and Chuck!!!!
Re: 428 R3 Block Build [Re: dwayne welder] #1559672
01/06/14 03:48 AM
01/06/14 03:48 AM
Trumbull,CT.
jim sciortino Online content
jim sciortino  Online Content
Trumbull,CT.
Cool.......keep em' coming.
Re: 428 R3 Block Build [Re: PETE@BESTMACHINE] #1559673
01/06/14 03:32 PM
01/06/14 03:32 PM
fullmetaljacket Offline
Pete. You and Chuck are mad scientists while in the closet of being artist.
Missed you guys in Detroit, was in and out.
Happy Holidays.
Re: 428 R3 Block Build [Re: fullmetaljacket] #1559674
01/06/14 04:13 PM
01/06/14 04:13 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
59 degree beast !
Re: 428 R3 Block Build [Re: tubtar] #1559675
01/06/14 05:11 PM
01/06/14 05:11 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
And all I can do is sit here and
Re: 428 R3 Block Build [Re: dartman366] #1559676
01/06/14 05:28 PM
01/06/14 05:28 PM
Arizona
410mopar Offline
410mopar  Offline
Arizona
How will you hold 14:1 compression with the top 4 cylinder head bolts removed??
Re: 428 R3 Block Build [Re: 410mopar] #1559677
01/06/14 06:29 PM
01/06/14 06:29 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
I would like to know as well. Not questioning. Just getting bad ideas for later down the road!
Back in the swing of things at Painless again! Great to be back!
Re: 428 R3 Block Build [Re: tubtar] #1559678
01/06/14 07:32 PM
01/06/14 07:32 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Cometic gasket mls head gasket. It's the same as a stock sb mopar engine now. You have never seen a sb mopar with compression?
Re: 428 R3 Block Build [Re: 1967dartgt] #1559679
01/06/14 08:59 PM
01/06/14 08:59 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
10 1/2" head studs will hold just fine.
With 7/16"in the original 10 the extra 8 3/8 bolts are necessary.
It appears a lot of clean up machining could be done on this block.
Re: 428 R3 Block Build [Re: 410mopar] #1559680
01/07/14 01:57 AM
01/07/14 01:57 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I ran my 416 at 14:1 with cometics and ARP studs with no problems, it is still running great for the new owner after 4 years and around 500 or so passes.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 428 R3 Block Build [Re: fullmetaljacket] #1559681
01/07/14 09:38 AM
01/07/14 09:38 AM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
Happy Holidays.
Yea and there Lab is something else
Re: 428 R3 Block Build [Re: dusturbd340W5] #1559682
01/07/14 01:14 PM
01/07/14 01:14 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
Haven't had any problems with mine either.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: 428 R3 Block Build [Re: Jacob Pitt] #1559683
01/07/14 01:30 PM
01/07/14 01:30 PM
long island new york
K
kingdust Offline
kingdust  Offline
K
I have an early R1 with diamond heads at 15.3 with a 1008 and don't have any problems. nice work by the way.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Page 1 of 3 1 2 3
