Elect. choke "?" #1559228
01/05/14 10:59 AM
01/05/14 10:59 AM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
Carb. with an Elect. choke on it. Going on a car that never had Elect. choke. Where would I get a source for the Elect. choke? How should it be wired?
OK, having looked at a few you tube vids. I see that the power source should come from a "key on" power source. Such as the "Ignition" area of the fuse box. This look Ok/make sense to you out there? I'm ready to start on this project.
Re: Elect. choke "?" [Re: bigblock340power] #1559229
01/05/14 11:45 AM
01/05/14 11:45 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The factory used the 12V feed to the ballast in applications that had electric assist chokes. It's a switched 12v and is usually a blue wire at the ballast. Just make sure it is the feed to the ballast side and not the output from the ballast to the coil.
Don't be the exception.
Re: Elect. choke "?" [Re: Supercuda] #1559230
01/05/14 12:02 PM
01/05/14 12:02 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Blue alternator field
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Elect. choke "?" [Re: bigblock340power] #1559231
01/05/14 12:58 PM
01/05/14 12:58 PM
As said the blue switched 12V wire that goes to the reg/alt. On my eddy 1406 the electric choke comes off WAY too fast. I just added one of those OE white bakelite devices from a 70's (80's?) eng which think delays it coming off when cold which is what I need. No idea if it worked as the car is non op right now
Re: Elect. choke "?" [Re: RapidRobert] #1559232
01/05/14 01:27 PM
01/05/14 01:27 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Uh-huh...
Re: Elect. choke "?" [Re: RSNOMO] #1559233
01/05/14 03:58 PM
01/05/14 03:58 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Uh-huh...
Here's the Holley aftermarket version:
http://www.summitracing.com/parts/hly-45-267/overview/
-Jim
Re: Elect. choke "?" [Re: 471Magnum] #1559234
01/05/14 04:35 PM
01/05/14 04:35 PM
SW MO
closer9 Offline
closer9  Offline
SW MO
Uh-huh...
hmmm... Looks like this might work with Edelbrock.
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: Elect. choke "?" [Re: closer9] #1559235
01/06/14 12:44 AM
01/06/14 12:44 AM
Elk Grove, Calif.
Elk Grove, Calif.
Bought an Edelbrock 1400 today for the old Dodge pickup. Went on without to much trouble. I wired the Elect. choke to a 12 volt "key on" power source from the fuse block. Ground wire to it's self. Instructions said not to get the power from the Alt., or ballast. I'm happy with it. Just wanted you all to know.
I guess I can post pics tomorrow if any ones interested.
Re: Elect. choke "?" [Re: bigblock340power] #1559236
01/06/14 02:50 PM
01/06/14 02:50 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Hey Mike'y.
Thought you were dead set on installing that Holley on the truck.
What changed your mind, to the Edelbrock?
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Elect. choke "?" [Re: RapidRobert] #1559237
01/06/14 03:13 PM
01/06/14 03:13 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
And just so you know, if you use that little white deal to supply the power voltage to an electric fuel pump, you can only drive till the engine warms up, then you get stranded on the side of the road, miles from home and are left scratching your head as to what you did wrong, because the ignition hot wire you found to run the pump now has no power.
Not that I would ever admit to doing this, but it could happen.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Elect. choke "?" [Re: hp383] #1559238
01/06/14 03:42 PM
01/06/14 03:42 PM
Sacramento, CA
cal_gecko Offline
cal_gecko  Offline
Sacramento, CA
a "choke" ... isn't that for people who live in cold weather? we don't need no stinking chokes here!
Re: Elect. choke "?" [Re: cal_gecko] #1559239
01/06/14 04:13 PM
01/06/14 04:13 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
But you're being choked and don't realize it !!
Re: Elect. choke "?" [Re: 62maxwgn] #1559240
01/06/14 04:40 PM
01/06/14 04:40 PM
Elk Grove, Calif.
Elk Grove, Calif.
Ok! I have a few pics to share. Laugh all you want. But I'm liking it.
Jim, I just couldn't get the divorced choke to work right. I couldn't get it to run right. The throttle shafts were bleeding vacuum leaks. I went with a Eddy cause of the elect. choke. Works great. I've lived and learned.
Gecko, my Duster doesn't have a choke, nor a choke horn for that matter. But she's a beast that doesn't let the weather bother her. The truck, on the other hand is still subject to smog laws.
Back to the pics.
