Re: Tell Me About B Body Fuel Tank Vent Tubes
[Re: Big Bad Bee]
#1559067
01/05/14 11:58 AM
01/05/14 11:58 AM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
Two different systems in 70. One for CA and one for 49 states. CA has a different tank with vents at the corners, and vapor separator mounted in the trunk, which in turn vented to the PCV system. And a bunch more hard lines and hoses connecting everything. 49 state vented direct to atmosphere. Unfortunately, I don't have a diagram handy of either that would answer your question. I'd need to find my 70 FSM and scan that page. I'm sure someone else can beat me to posting it.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: 471Magnum]
#1559068
01/05/14 01:39 PM
01/05/14 01:39 PM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
Here is pic from the '70 Plymouth FSM (don't have a Dodge one). I ASSuME it would be the same. These are non CA emissions. If you want the CA pic, let me know. - Alan EDIT: just realized I took wrong pics from FSM, will correct shortly EDIT: pic corrected. Looks the same as one posted above.
[Re: Big Bad Bee]
#1559073
01/06/14 08:40 PM
01/06/14 08:40 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Here's a picture of a trunk floor, this is a 69 convertible. Ron
YES! Ron, Alan, this is just what I need! Now the other line appears to just dump directly out in front of the axle? Regardless, this is great stuff.
yes, it clips to the frame where the shock mount.
