Re: bypass hose ??
[Re: Andrewh]
#1559009
01/05/14 01:57 AM
01/05/14 01:57 AM
RapidRobert
I've always wondered if that bypass can be partly blocked as it seems like alot of volume moves thru it & a BB has a very small bypass inside the pump housing. yes with no stat you can block it but circle track racing is the only racing (that I am aware of) where you dont run a stat
Re: bypass hose ??
[Re: stumpy]
#1559011
01/05/14 02:34 AM
01/05/14 02:34 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Bypass is needed. Unless you remove the T-stat.
Cold water in the engine = closed thermostat
Closed thermostat means no flow. No flow means that the water around the chamber will heat up, but the radiator can't cool it off until the water heat soaks enough to open the stat.
By that time, you've already boiled the water by the chamber and possibly overheated your heads.
Ever watch a pot boil? You get steam bubbles forming at the bottom of the pot before the water truely boils.
Unless you stir the pot to even out the temps so that the water heats evenly. This is what the bypass does. It circulates the water in the engine only until its hot enough to open the t-stat.
**Photobucket sucks**
