Page 1 of 3 1 2 3
Lets see your 72-93 Dodge 2wd With 17" wheels #1557166
01/01/14 03:34 AM
01/01/14 03:34 AM
Iowa
76dodgeboy Offline OP
Iowa
Lets see What you got and please give tire size. Need an idea what size looks good ony truck. Thanks
Re: Lets see your 72-93 Dodge 2wd With 17" wheels [Re: 76dodgeboy] #1557167
01/01/14 03:57 PM
01/01/14 03:57 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Here's a couple, stock and lowered ... if you were looking for 2wd.
It takes gasoline to interest me.
Re: Lets see your 72-93 Dodge 2wd With 17" wheels [Re: VL21] #1557168
01/01/14 04:00 PM
01/01/14 04:00 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
275/60-17, down 3" rear and about 2 or 2 1/2" in front
Re: Lets see your 72-93 Dodge 2wd With 17" wheels [Re: VL21] #1557169
01/01/14 07:21 PM
01/01/14 07:21 PM
Iowa
Iowa
Yeah title states 2wd. Thanks. Those might be too tall. I'll be much lower too
Re: Lets see your 72-93 Dodge 2wd With 17" wheels [Re: 76dodgeboy] #1557170
01/01/14 07:32 PM
01/01/14 07:32 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The 255/70/15's on my RC are almost if not the same height as the 275/60/17's on my SS/T
Re: Lets see your 72-93 Dodge 2wd With 17" wheels [Re: BulletBob] #1557171
01/01/14 08:48 PM
01/01/14 08:48 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
the 70 series to the 60 series should be an inch shorter. really just depends on the manufacturer
Re: Lets see your 72-93 Dodge 2wd With 17" wheels [Re: 72d100] #1557172
01/01/14 09:08 PM
01/01/14 09:08 PM
Iowa
Iowa
I'll be close to this low.
Re: Lets see your 72-93 Dodge 2wd With 17" wheels [Re: 76dodgeboy] #1557173
01/01/14 09:38 PM
01/01/14 09:38 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
that looks like you will be close to a 35 series tire. how are you planning on guying that low?
Re: Lets see your 72-93 Dodge 2wd With 17" wheels [Re: 76dodgeboy] #1557174
01/01/14 10:42 PM
01/01/14 10:42 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Yeah, saw the 2wd AFTER I posted. My bad.
These are a pretty tall tire, but they are what I had to work with.
I would have liked to go lower, but this one is going to have to earn it's keep, some hauling is in its future ...not going to get much beyond this, probably not even paint.
Re: Lets see your 72-93 Dodge 2wd With 17" wheels [Re: VL21] #1557175
01/02/14 01:00 AM
01/02/14 01:00 AM
Iowa
Iowa
He's running 20"s in it. Simple to get that low. Dakota drop spindle and van lower arms in front or Dakota drop spindle and cut coils. rear is axle flip notch and hanger flip and drop shackle. He has a lowering block. I plan to use a front hanger in the rear with a drop shackle.
Re: Lets see your 72-93 Dodge 2wd With 17" wheels [Re: 76dodgeboy] #1557176
01/02/14 01:02 AM
01/02/14 01:02 AM
Iowa
Iowa
Re: Lets see your 72-93 Dodge 2wd With 17" wheels [Re: 76dodgeboy] #1557177
01/02/14 01:54 AM
01/02/14 01:54 AM
Iowa
Iowa
I won't need 35series tires. 55/60 should be fine. Waiting to see what sizes people are running to get an idea what the look like. 30" tire is a little taller than I want.
Re: Lets see your 72-93 Dodge 2wd With 17" wheels [Re: 76dodgeboy] #1557178
01/02/14 02:11 AM
01/02/14 02:11 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Here is the 80 as it sat with the /6. Van LCA's with the 2" drop spindles, new springs no cuts. 15x7 front with 235/60 and 15x8 rear with 275/60.
Re: Lets see your 72-93 Dodge 2wd With 17" wheels [Re: 77ProStreet] #1557179
01/02/14 02:20 AM
01/02/14 02:20 AM
Iowa
Iowa
Thanks but looking for pics with 17" wheels. Ivy had numerous 15" myself. Good Looking truck!
Re: Lets see your 72-93 Dodge 2wd With 17" wheels [Re: 76dodgeboy] #1557180
01/03/14 10:44 PM
01/03/14 10:44 PM
Iowa
Iowa
KevinI Corronet440(?) Rumblebee What's your Tire Combo? I think Cheeto has 18s
Re: Lets see your 72-93 Dodge 2wd With 17" wheels [Re: VL21] #1557181
01/04/14 11:23 AM
01/04/14 11:23 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
VL21 I like your ride That is my idea of what a working truck should look like. At the moment I am running 245/75R16s on aftermarket rims on my '87. I could see some 17s in its future after I replace the cut coils and shocks on the front. Mine has to work for a living, too.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Lets see your 72-93 Dodge 2wd With 17" wheels [Re: 76dodgeboy] #1557182
01/11/14 08:59 PM
01/11/14 08:59 PM
Iowa
Iowa
Nobody?
Re: Lets see your 72-93 Dodge 2wd With 17" wheels [Re: 76dodgeboy] #1557183
01/15/14 12:04 PM
01/15/14 12:04 PM
Dearborn, Michigan
jstollfu Offline
jstollfu  Offline
Dearborn, Michigan
Mine has 17's. BTW you won't really be able to drive that truck sitting that low. Mine is about as low as practical for any sort of daily driving and I still have to be careful were I go. But I'm sure you know more then I do! Josh-
Re: Lets see your 72-93 Dodge 2wd With 17" wheels [Re: jstollfu] #1557184
01/16/14 01:06 AM
01/16/14 01:06 AM
Iowa
Iowa
The kid with the blue truck says he drove it all over. I do want it that low but my driveway I don't thing Will allow for one but Im tossing around the idea of the bags that go inside the coils and the helper bags for the rear for a few years and later on when my Fabrication skills are better doing an actual air ride. I drove my clubcab daily with it sitting on re bumostop brackets. The front hub was 13" from the fender lip. I had to jack it up to jack it up lol. If it always hits it'll get raised up some. Lets see some pics of your truck. Yours is the 2tone brown and tan isn't it? What size tires?
Re: Lets see your 72-93 Dodge 2wd With 17" wheels [Re: jstollfu] #1557185
01/17/14 01:23 AM
01/17/14 01:23 AM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
Man that is One Sweet looking ride....Nice job.
Page 1 of 3 1 2 3
