Using stock springs with another cam
#155714
11/24/08 08:37 AM
11/24/08 08:37 AM
Posts: 5,167 CT
GTX MATT
CT
If I was to use stock springs with say the Comp XE268, what problems might I run into? I know I will loose power and valve float will come in sooner, but how much am I really going to loose in the heart of the powerband?
Am I risking anything dangerous.
Re: Using stock springs with another cam
[Re: GTX MATT]
#155718
11/25/08 02:34 AM
11/25/08 02:34 AM
Posts: 132 Kingman, Az
Scojodak
Kingman, Az
Change the springs and be done with it. Change the seals too while you're that into it. Just mt $.02
Dakota for life!
[Re: MoparforLife]
#155721
11/25/08 09:07 AM
11/25/08 09:07 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
the recommended comp 901's for that cam are less than $70, and can use the stock retainers (as long as you replace the rotator retainers on the exhaust valves--of so equipped-- with standard ones)
