Big block automatic overdrive tranny?
#1557106
12/31/13 11:53 PM
12/31/13 11:53 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Is there a good Dodge overdrive automatic tranny to fit behind a big block? I am gonna build a road car when the AAR is done from a 71 Charger 500 big block car and was gonna put a hgih gear in it so that I can run 80 without twisting the motor so hard. Then I got to wondering if they made a big block OD automatic. I know OD trannies weren't popular until the 80s and I think big blocks were gone by then was there an overlap? Or is a 727 with a lock up convertor the best I can do?
Thanks in advance, Kevin
Careful, your character's showing!
Re: Big block automatic overdrive tranny?
[Re: Kern Dog]
#1557108
01/01/14 12:11 AM
01/01/14 12:11 AM
mopar346
Thank you, I didn't think so but I figured I'd ask. I'm familiar with the bellhousing option, we ran a glide in a Dart years ago and my brother is building a GTX for a guy with 4l60e (or whatever it is) behind a 540 aluminum Hemi. Will a 500 or 518 hold up behind a moderate big block?
[Re: mopar346]
#1557110
01/01/14 12:16 AM
01/01/14 12:16 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
The 360/518 would be your best choice. The 500 was used behind the V6/V8 318S.
I am truckless..
[Re: 340SHORTY]
#1557111
01/01/14 12:20 AM
01/01/14 12:20 AM
mopar346
I agree a 360 or stroked small block would be the easiest route but it is a BB HP car and I would like to maintain that aspect of it. I figure the torque of a big block should overcome a high gear and still give decent out of the hole performance.
[Re: mopar346]
#1557112
01/01/14 12:28 AM
01/01/14 12:28 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I dissagree. Putting a small block into your B-Body should NEVER be an acceptable option. There are other OD options. A gear venders OD unit seems to be the best option for BB guys. GV units go for around 3k, though. But it beats running around with a little motor. ![](/ubbthreads/images/graemlins/stirthepot.gif) Not to mention, even with a little motor, you'll have to do some significant floor surgury to get the Chrysler OD trans to fit into an older Charger. So, could the BEST option REALLY be to neuter your Charger with a small block, AND cut the floor all up to do it???? ![](/ubbthreads/images/graemlins/image_294343.gif)
[Re: StealthWedge67]
#1557113
01/01/14 01:11 AM
01/01/14 01:11 AM
mopar346
Definitely no floor cutting gonna happen, it is a solid original floor car, not too many of those left.
