Re: HEMI Ray Barton crossram VS Indy tunnel ram
[Re: Mulehead]
#1556959
12/31/13 06:50 PM
12/31/13 06:50 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
I wouldn`t expect much of a gain in performance . My 557 " runs fine with a RBRE / single 1050 Dominator set up and is making 875 HP . A LOT easier to tune as well . $0.02 Happy New Year ! ![](http://i1131.photobucket.com/albums/m553/debobs557/DSC_0332_zps2bc6d107.jpg)
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: Bishop]
#1556962
01/01/14 09:13 AM
01/01/14 09:13 AM
Posts: 1,633 pa
572charger
pa
it will be close ive got one on my charger and i have a 68 super stock hemi hood scoop on mine it fits under ,but mine is 1" taller scoop , i may be able to measure it to day ,i know the carbs are( 850s)slightly above the hood
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: Bishop]
#1556965
01/04/14 02:37 PM
01/04/14 02:37 PM
Posts: 1,141 Phoenix,Az.
hemicop
Phoenix,Az.
If RBRE did your motor, I'd talk to them. Think back on just what a x-ram is. Essentially it's a horizontal tunnelram, so the only real benefit, IMO, would be you're straightening out the path of your incoming mixture. Now how much that's worth, I'm guessing would ( as was said) depend on your combo, where the power is made & what you're trying to accomplish.If the car is only a local/bracket car it may not be worth it. If you're going for every last once of HP & ET, then you need to consult with someone that knows your combo & not just gamble on opinions.
[Re: Bishop]
#1556966
01/05/14 02:55 AM
01/05/14 02:55 AM
Posts: 1,186 OHIO
THE GLASS MAN
OHIO
I have a Sled city Fiberglas AFX Hemi scoop on my 64 just wonder if it will fit under the hood
Nice scoop! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: THE GLASS MAN]
#1556967
01/05/14 08:22 AM
01/05/14 08:22 AM
Posts: 1,633 pa
572charger
pa
my rear carb on the indy hemi tunnel ram sticks out of the hood about 2 1/2 inches to the top of the fuel bowl vent ![](/ubbthreads/images/graemlins/Twocents.gif)
