Body work question for those 'sperienced.
#1556935
12/31/13 05:11 PM
12/31/13 05:11 PM
Posts: 85 Lavonia, GA
cjbill
Lavonia, GA
In continuing to do my underhood clean-up on the '69 300, the driver inner fender has several 3/8" holes from one of the PO's mounting "something" there. Since it is underhood and exposed to higher than normal temps, is it okay to just fill the holes with bondo or use small squares of fiberglass instead before blending and painting?
ex-Ford guy, but Mopars nowadays
Re: Body work question for those 'sperienced.
[Re: cjbill]
#1556936
12/31/13 05:24 PM
12/31/13 05:24 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Weld them then finish them off..
I am truckless..
[Re: 340SHORTY]
#1556937
12/31/13 05:30 PM
12/31/13 05:30 PM
cjbill
Lavonia, GA
Unfortunately, unable to weld.
[Re: Challenger 1]
#1556939
12/31/13 05:39 PM
12/31/13 05:39 PM
cjbill
Lavonia, GA
Learn
Wow, thanks for the advice, folks, just what I was looking for, I can weld, but am unable to at the moment (welder in storage)...let me put it this way, don't WANT to weld.
[Re: cjbill]
#1556940
12/31/13 05:55 PM
12/31/13 05:55 PM
Challenger 1
Cincinnati, Ohio
Learn
You even have a welder and don't want to learn?
[Re: Challenger 1]
#1556941
12/31/13 06:00 PM
12/31/13 06:00 PM
cjbill
Lavonia, GA
No, have a welder, know how (at least basically), but welder in storage about 300 miles away. Stuck right now. Just looking for things that I "can" do right now, instead of sitting on my butt all winter, watching TV, and thinking about doing it.
[Re: cjbill]
#1556944
12/31/13 09:26 PM
12/31/13 09:26 PM
Posts: 4,437 Omaha Nebraska
Brian_wo
Omaha Nebraska
Do it right Find somebody close with a mini mig and weld it,you will be glad you did.
who is that guy?
[Re: BulletBob]
#1556947
12/31/13 10:16 PM
12/31/13 10:16 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
Welding creates rust
To be a bit more accurate...Welding does not create rust. Improper finishing of the welded metal creates rust.
Either weld the holes or find something else to do under the hood until you are able to borrow a welder or retrieve yours. Anything worth doing is worth doing right and glass or filler is NOT the proper or permanent way to fill those holes.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: cjbill]
#1556949
12/31/13 11:00 PM
12/31/13 11:00 PM
cjbill
Lavonia, GA
Thanks for the advice, all, think I may "try" the bondo thing out on a trial piece of metal first. If I don't like the results, since I am a novice at the whole bondo/fill thing, I'll try to find someone around with a MIG who is willing to attempt it.
[Re: cjbill]
#1556952
01/01/14 09:22 PM
01/01/14 09:22 PM
Posts: 1,572 Jacksonville Florida
elitecustombody
I agree with everyone, do what's right,not what's easy. You might be able to get a cheap flux core welder at Harbor Freight.With 25% off coupon it might be around $50 lol! But if you still can not get a welder,use panel bonding adhesive. Many brands on the market like 3M,SEM,Norton,Fusor,Dominion Seal, Wurth,etc. It works best on ground clean metal.
