big block bracket question #1556819
12/31/13 01:50 PM
12/31/13 01:50 PM
Poplar Bluff, Missouri
partfiler69 Offline OP
Still Wondering
Still Wondering
Does anybody know a place to get power steering brackets for an AC equipped big block? I've looked at 440source and classic industries. All I can find are non AC brackets. This is for a 1973 Satellite with a 400. If I have to go junkyard scrounging, what years will interchange? I believe I have to find 73+ brackets, but not 100% sure. Any help is appreciated.
Back from hiatus
Re: big block bracket question [Re: partfiler69] #1556820
12/31/13 02:25 PM
12/31/13 02:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Check Bouchilion , PS isn't A/C specific .
Re: big block bracket question [Re: JohnRR] #1556821
12/31/13 02:43 PM
12/31/13 02:43 PM
Still Wondering
Still Wondering
Thanks for the tip, John. But their brackets look like the ones that 440source said will not work. I guess I will give them a call after the holidays. From what I've read, if it had AC, the brackets had a different spacing so everything would line up. Here is a pic of what I BELIEVE I need, lol
Re: big block bracket question [Re: partfiler69] #1556822
12/31/13 05:43 PM
12/31/13 05:43 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
My is John RR is right. Here's a pic of my engine, formerly non a/c, but I added a Sanden coompressor to modified factory a/c compressor brackets and used the same power steering pump on run of the mill bb saginaw pump brackets. You will need to change the alternator brackets to a/c style and use crank, wp and idler pulley setup from a bb a/c application. I believe the pic you have is from a truck/motorhome application that hangs the pump down pretty low. Hope this is some help.
jess
Yeah, it's hopped up to over 160...
Re: big block bracket question [Re: jt4406] #1556823
12/31/13 05:44 PM
12/31/13 05:44 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
view from other side
Re: big block bracket question [Re: jt4406] #1556824
12/31/13 06:15 PM
12/31/13 06:15 PM
Lavonia, GA
cjbill Offline
cjbill  Offline
Lavonia, GA
Kudos on the Sanden compressor conversion. Me likey!
ex-Ford guy, but Mopars nowadays
Re: big block bracket question [Re: cjbill] #1556825
12/31/13 09:05 PM
12/31/13 09:05 PM
Still Wondering
Still Wondering
Thanks for the help, guys. I guess I'll go ahead and order their brackets and see how it fits. I was under the impression that it had to be mounted lower, but I have no clue.
Back from hiatus
Re: big block bracket question [Re: partfiler69] #1556826
12/31/13 09:15 PM
12/31/13 09:15 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I'm using Bouchillon big block brackets for Sanden AC compressor and their brackets for power steering on the same car. Everything fit and works fine.
Re: big block bracket question [Re: partfiler69] #1556827
01/01/14 05:20 PM
01/01/14 05:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'll ask the stupid question ... Are you looking to have a 1973 CORRECT look under the hood ? You can't just mix and match stuff unfortunately , the pulleys and brackets all need to work together .
If you are after the look of the picture you posted above , or you have most of those parts , then you'll need the 73 brackets , which I don't think is what Bouchillion sells. If all you want is power steering and A/C then order the Bouchillion brackets AND the pulleys they have.
That 73 setup is mostly the smae with or without air , on it is uses the PS as the idler adjustment for the waterpump, earlier setup never had the waterpump and PS on the same belt.
Re: big block bracket question [Re: JohnRR] #1556828
01/01/14 05:29 PM
01/01/14 05:29 PM
Still Wondering
Still Wondering
I'm not looking for a period correct restro, just something that will work correctly, without the belt jumping off. Since I dont know what I needed, I figured I'd try to find what came on the car originally. Anything that will work will be fine. Thank for all the help.
Back from hiatus
Re: big block bracket question [Re: partfiler69] #1556829
01/01/14 05:31 PM
01/01/14 05:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What parts do you have now ?
Re: big block bracket question [Re: JohnRR] #1556830
01/01/14 05:37 PM
01/01/14 05:37 PM
Still Wondering
Still Wondering
This is all I have. You may have to zoom my crappy cell phone pic.
Back from hiatus
Re: big block bracket question [Re: JohnRR] #1556831
01/01/14 05:53 PM
01/01/14 05:53 PM
Still Wondering
Still Wondering
All my pics are too large. But, im pretty much starting from scratch.
Back from hiatus
Re: big block bracket question [Re: partfiler69] #1556832
01/01/14 05:57 PM
01/01/14 05:57 PM
Still Wondering
Still Wondering
I have the small flat piece that is bolted to the water pump housing.
Back from hiatus
Re: big block bracket question [Re: partfiler69] #1556833
01/01/14 06:48 PM
01/01/14 06:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you mahe nothing then you can swich over , your first thin to figure out is the lower pulley , I have a couple of A/C lower pulleys I let go for cheap to save you money , one is a 3 pulley, the other is a 4 , 30 shipped.
Re: big block bracket question [Re: JohnRR] #1556834
01/02/14 12:26 AM
01/02/14 12:26 AM
Still Wondering
Still Wondering
I appreciate it, but I have all the pulleys, the only thing I lack is the PS pump brackets.
Back from hiatus
Re: big block bracket question [Re: partfiler69] #1556835
01/02/14 12:45 PM
01/02/14 12:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What pulleys do you have ? the correct 73 ones or a pile of pulleys you've collected ?
Re: big block bracket question [Re: JohnRR] #1556836
01/02/14 02:03 PM
01/02/14 02:03 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
before dropping a pile of cash to use v belt check out our serpentine belt conversion...
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: big block bracket question [Re: Jerry] #1556837
01/02/14 02:07 PM
01/02/14 02:07 PM
Still Wondering
Still Wondering
I have all the correct pulleys. I bought the engine complete minus the PS pump and AC compressor. Im sorry, john. I had a brain fart when you asked what I had. I thought you meant bracket wise. Please excuse my blond moment, lol
