Re: Is 380 mm rotors large enough for you?
[Re: Uhcoog1]
#1556606
01/03/14 12:12 AM
01/03/14 12:12 AM
Posts: 256 USA
Consulier
USA
Nope, large SUV, they have the largest brakes of any 1/2 class ton suv out there....
.... and that is?
SRT8 Grand Cherokee Why a secret i have no idea.
[Re: Consulier]
#1556607
01/03/14 05:16 AM
01/03/14 05:16 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I just wanted to have some fun with it.. Yep, the SRT8 GC...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1556608
01/03/14 09:38 AM
01/03/14 09:38 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Those F1 cars with their carbon fiber brakes are impressive for sure.
talking to a ferrari owner who abused his car the way it was built for, said that his carbon fiber rotors cost him $15,000 to replace when they were finally worn out.
**Photobucket sucks**
[Re: jcc]
#1556611
01/05/14 01:58 PM
01/05/14 01:58 PM
astjp2
Utah and Alaska
I think I may build this combination, I found some 18" steel wheels that may fit if I cut the centers out and move the back spacing to the center. If I use the discount rotors and get a rebuilt caliper, I can fit it up quite well before it ever goes on a car. Tim
[Re: feets]
#1556613
01/07/14 05:31 AM
01/07/14 05:31 AM
astjp2
Utah and Alaska
These are the rotors I have now, the caliper clearance sucked but I found stock 17" steel wheels that cleared the calipers. I cut the centers out of the wheel, recentered them, and welded them in. Its a 17x7.5" wheel with 3.5" of back spacing. The reason I used these if the fact that I can bolt the brackets on the drum spindles and everything clears. Modern brakes for 200.00 in salvage yard parts. Comes with dual piston calipers and 12" rotors. Tim
[Re: astjp2]
#1556614
01/07/14 05:33 AM
01/07/14 05:33 AM
astjp2
Utah and Alaska
This is the mockup of 12" rotors before they are put on the car.
[Re: astjp2]
#1556615
01/07/14 05:38 AM
01/07/14 05:38 AM
astjp2
Utah and Alaska
Bracket and spindle installed...
[Re: OzHemi]
#1556618
02/01/14 04:11 PM
02/01/14 04:11 PM
astjp2
Utah and Alaska
The grand Cherokee has 6 piston calipers. I am going to try a high clearance 18" wheel first, if not, then I can look at 19" wheels. I will have less that 700 in the whole project. I have made the setup for 12" rotors with dual piston calipers that bolted up to the drum spindles and hubs. Its the challenge of making something different that I enjoy. Tim
[Re: OzHemi]
#1556620
02/02/14 10:16 PM
02/02/14 10:16 PM
astjp2
Utah and Alaska
Rotors should be here by wed morning. Amazon was awesome for that price and free shipping.
[Re: OzHemi]
#1556622
02/02/14 11:26 PM
02/02/14 11:26 PM
astjp2
Utah and Alaska
I wish Feets would do some of the math so I know what size master cylinder I should run. I was looking at Marauder wheels. 5x4.5 with the same register as mopar. Tim
