Page 2 of 7 1 2 3 4 5 6 7
Re: Is 380 mm rotors large enough for you? [Re: astjp2] #1556605
01/02/14 06:46 PM
01/02/14 06:46 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Nope, large SUV, they have the largest brakes of any 1/2 class ton suv out there....
.... and that is?
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Is 380 mm rotors large enough for you? [Re: Uhcoog1] #1556606
01/03/14 01:12 AM
01/03/14 01:12 AM
USA
Consulier Offline
Consulier  Offline
USA
.... and that is?
SRT8 Grand Cherokee
Why a secret i have no idea.
Re: Is 380 mm rotors large enough for you? [Re: Consulier] #1556607
01/03/14 06:16 AM
01/03/14 06:16 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I just wanted to have some fun with it.. Yep, the SRT8 GC...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Is 380 mm rotors large enough for you? [Re: astjp2] #1556608
01/03/14 10:38 AM
01/03/14 10:38 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Those F1 cars with their carbon fiber brakes are impressive for sure.
talking to a ferrari owner who abused his car the way it was built for, said that his carbon fiber rotors cost him $15,000 to replace when they were finally worn out.
**Photobucket sucks**
Re: Is 380 mm rotors large enough for you? [Re: 70Cuda383] #1556609
01/05/14 02:31 AM
01/05/14 02:31 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Carbon brakes are old technology from the 1980's The energy conversion is newer...
http://www.boeing.com/commercial/aeromagazine/articles/qtr_03_09/article_05_1.html
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Is 380 mm rotors large enough for you? [Re: astjp2] #1556610
01/05/14 12:32 PM
01/05/14 12:32 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
That was an interesting link
Re: Is 380 mm rotors large enough for you? [Re: jcc] #1556611
01/05/14 02:58 PM
01/05/14 02:58 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I think I may build this combination, I found some 18" steel wheels that may fit if I cut the centers out and move the back spacing to the center. If I use the discount rotors and get a rebuilt caliper, I can fit it up quite well before it ever goes on a car. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Is 380 mm rotors large enough for you? [Re: astjp2] #1556612
01/06/14 10:23 PM
01/06/14 10:23 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That must be a really impressive steel wheel.
I haven't seen one yet that will clear a caliper that size on a rotor as shallow as those.
I strongly suggest you find a SRT Jeep and break out a measuring device. The center hat of the rotor is less than an inch away from the rotor surface. The caliper sticks out nearly three inches from the surface of the rotor.
Your wheels are going to smash the caliper before you can get the lug nuts on. There's a good chance it will contact the outer radius of the caliper too.
Mission: Impossible.
- Stu Harmon
Re: Is 380 mm rotors large enough for you? [Re: feets] #1556613
01/07/14 06:31 AM
01/07/14 06:31 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
These are the rotors I have now, the caliper clearance sucked but I found stock 17" steel wheels that cleared the calipers. I cut the centers out of the wheel, recentered them, and welded them in. Its a 17x7.5" wheel with 3.5" of back spacing. The reason I used these if the fact that I can bolt the brackets on the drum spindles and everything clears. Modern brakes for 200.00 in salvage yard parts. Comes with dual piston calipers and 12" rotors. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Is 380 mm rotors large enough for you? [Re: astjp2] #1556614
01/07/14 06:33 AM
01/07/14 06:33 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
This is the mockup of 12" rotors before they are put on the car.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Is 380 mm rotors large enough for you? [Re: astjp2] #1556615
01/07/14 06:38 AM
01/07/14 06:38 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Bracket and spindle installed...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Is 380 mm rotors large enough for you? [Re: astjp2] #1556616
02/01/14 05:35 AM
02/01/14 05:35 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
So I was poking around Amazon yesterday and found Raybestos pro grade rotors 380mm for $43.99 each, so I dropped the hammer and ordered a pair and with prime it was free shipping. Now I just need to find calipers in a salvage yard...Then its measure up and make new brackets....for the largest brakes I can fit on a 68 Charger. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Is 380 mm rotors large enough for you? [Re: astjp2] #1556617
02/01/14 02:13 PM
02/01/14 02:13 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Are you going with 6 or 8 piston calipers with those rotors?
And obviously it will be 19" and up wheels..
Re: Is 380 mm rotors large enough for you? [Re: OzHemi] #1556618
02/01/14 05:11 PM
02/01/14 05:11 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
The grand Cherokee has 6 piston calipers. I am going to try a high clearance 18" wheel first, if not, then I can look at 19" wheels. I will have less that 700 in the whole project. I have made the setup for 12" rotors with dual piston calipers that bolted up to the drum spindles and hubs. Its the challenge of making something different that I enjoy. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Is 380 mm rotors large enough for you? [Re: astjp2] #1556619
02/01/14 06:03 PM
02/01/14 06:03 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
That would be mighty tight with an 18" wheel I would guess. My rotors are 360mm, and with how the 8 piston calipers sit on them...it is does fit under an 18, but not a ton of room to spare. With the extra 20mm in diameter...so 10mm on one "end" so to speak pushing the caliper out further be interesting to see how it goes squeezing into the same sized wheel. (and depending on the shape of the top of the Jeep caliper too )
Re: Is 380 mm rotors large enough for you? [Re: OzHemi] #1556620
02/02/14 11:16 PM
02/02/14 11:16 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Rotors should be here by wed morning. Amazon was awesome for that price and free shipping.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Is 380 mm rotors large enough for you? [Re: astjp2] #1556621
02/02/14 11:26 PM
02/02/14 11:26 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Those rotors are pretty flat too...probably have to make sure you use a wheel with a thick enough mounting pad to get the spokes,etc far enough away for caliper clearance, or just wheels that curve outward somewhat.
They are a little thinner than the ones I use, so at least that helps offset the weight with the extra diameter.
Re: Is 380 mm rotors large enough for you? [Re: OzHemi] #1556622
02/03/14 12:26 AM
02/03/14 12:26 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I wish Feets would do some of the math so I know what size master cylinder I should run. I was looking at Marauder wheels. 5x4.5 with the same register as mopar. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Is 380 mm rotors large enough for you? [Re: astjp2] #1556623
02/03/14 12:34 AM
02/03/14 12:34 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I use a 1" with my setup.
Re: Is 380 mm rotors large enough for you? [Re: astjp2] #1556624
02/03/14 04:58 PM
02/03/14 04:58 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I don't know what size pistons you're playing with.
Did you try get the numbers and plug them into the spreadsheet?
- Stu Harmon
