1971 charger 11 inch rear drum question
#1556432
12/30/13 11:02 PM
12/30/13 11:02 PM
Posts: 1,347 Wahoo Nebr
vette1986
Wahoo Nebr
Hey Guys, Well I pulled the brakes off my 71 rt and the brakes need help! It is missing the self adjusters, springs are all messed up as some broke and they just bent them over and streched them, and it is missing alot of stuff. So I need a complete rear brake kit with shoes, springs, self adjusters and gaskets. Any idea who makes these as no one has the kit with all the hardware. Thanks
1969.5 A12 Bee EV2 1971 Charger RT 1973 Duster tubbed 500 low deck 10.90 monster 3 440 polara vert projects
Re: 1971 charger 11 inch rear drum question
[Re: Moparnut426]
#1556436
12/31/13 01:38 AM
12/31/13 01:38 AM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
No complete kit that has the adjuster lever, half moon cable adjuster guides, pegs for the adjuster lever, and all the springs. It's missing everything but the actual threaded adjusters
Check RockAuto. I just looked and it seems like they have everything. Not in a single kit.
[Re: DAYCLONA]
#1556438
12/31/13 01:46 AM
12/31/13 01:46 AM
Posts: 12,016 Finally a HUSKER again
Moparnut426
Autozone/Duralast PN#
Shoes pn#335/ alternate PN# 335CP All in one spring kit pn#H7250 Star Adjusters and pin kit pn# H2534 drivers, and pn# H2535 passenger Wheel cylinders pn#33597 order 2
That's everything available, do the cylinders as long as your in there, cheap insurance, everything should run you $75
Awesome! Ill head over there in the morning and get it all off these numbers. The wheel cylinders look brand new btw. I pulled the rubbers back and they were dry
Mike
