detonation with just bad amin bearing wear #1555409
12/30/13 12:43 AM
12/30/13 12:43 AM
Gettysburg Pa
roadrunnerreds Offline OP
Gettysburg Pa
Pulled my 360 to freshen it and get to mains and the bottom halfs are brassy but tops look ok rod bearings are ok.
Re: detonation with just bad amin bearing wear [Re: roadrunnerreds] #1555410
12/30/13 12:53 AM
12/30/13 12:53 AM
British Columbia
toddd Offline
toddd  Offline
British Columbia
What do the main caps look like?.
Can you post a pic of the bearing?
Re: detonation with just bad amin bearing wear [Re: roadrunnerreds] #1555411
12/30/13 02:44 AM
12/30/13 02:44 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Sounds like it needs line honed. Improper bearing crush or possibly bent crank
Monte
Re: detonation with just bad amin bearing wear [Re: Monte_Smith] #1555412
12/30/13 03:05 PM
12/30/13 03:05 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
If its detonation the upper rod bearings will show it as funny where or will be under size on a micrometer.
Re: detonation with just bad amin bearing wear [Re: FastmOp] #1555413
12/30/13 03:16 PM
12/30/13 03:16 PM
MR_P_BODY Offline
Happy Birthday MR_P_BODY  Offline
I've never seen detonation on just a main bearing..
the rods would show it before the mains... has to
transfer the detonation from the piston to the crank
somehow
Re: detonation with just bad amin bearing wear [Re: Monte_Smith] #1555414
12/30/13 03:49 PM
12/30/13 03:49 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Monte
as reasonable an answer as I have heard yet, are these the caps that came with the block?
Re: detonation with just bad amin bearing wear [Re: dartman366] #1555415
12/31/13 10:51 AM
12/31/13 10:51 AM
Gettysburg Pa
Gettysburg Pa
Yes it is the crank that was in engine before. Caps have marks indicating cap walk.
