need 77 new yorker brake caliper bracket,same as? #1555386
12/29/13 10:29 PM
12/29/13 10:29 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I need the front brake caliper brackets for a 77 new yorker. What other years and cars are the same? I know they used the caliper on a lot of cars and even trucks , I found that list, but I don't know if they used the same. Bracket?
Re: need 77 new yorker brake caliper bracket,same as? [Re: dirt] #1555387
12/30/13 12:01 PM
12/30/13 12:01 PM
moparx Offline
moparx  Offline
at least 74-78 newyorker & newport. try 1/2 ton d100's also.
Re: need 77 new yorker brake caliper bracket,same as? [Re: moparx] #1555388
12/30/13 02:18 PM
12/30/13 02:18 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Slider or pin type?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: need 77 new yorker brake caliper bracket,same as? [Re: Magnumguy] #1555389
12/30/13 07:41 PM
12/30/13 07:41 PM
Houston
I
it's Bob Offline
it's Bob  Offline
I
Houston
Pretty sure all '74 up C Bodies were slider calipers. I have never see a pin type caliper adapter on a '74 up C body. Also I second the advice to check '74-5 up D150 part numbers for an interchange.
Bob
Re: need 77 new yorker brake caliper bracket,same as? [Re: it's Bob] #1555390
12/31/13 12:28 AM
12/31/13 12:28 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I found a set of brackets today. I am working on a disc brake swap onto a 68 d100 sweptline. I have one adapter plate and just need to make another one for the otber side.
