Re: progress on my 42 dodge truck.
[Re: 2abodymcodes]
#1555353
06/28/14 08:22 PM
06/28/14 08:22 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
i think i am going to need a shroud or do away with my mech fan and put electric fans. getting some advice on that in another thread right now.
With that much room, maybe you could find two baby fans to put above your mechanical one. Just a thought.
[Re: 2abodymcodes]
#1555355
06/28/14 08:35 PM
06/28/14 08:35 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
[Re: 2abodymcodes]
#1555359
06/29/14 06:40 AM
06/29/14 06:40 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
you have the same problem most rods do, the fan is too low,the hot water enters the radiator at the top,,,if your running a vee belt system and not a serpintime belt,,,there is a fix to run your mech fan,,,1 build a custom shroud,,or this is the best,,,find a 1960 dodge truck 318 poly,,ive heard some motor homes also use this,,they have a special timing chain/water pump cover,,,it raises the water pump up higher then normal,,it would put it in the middle or higher on your radiator,,,or get a street rod electric fan with built in shroud use it on the engine side puller,,much better then a pusher fan,,,some fans such as the cooling componets fans,,require a lot of amperage,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
